95LEGOBW Posted February 25, 2008 Share Posted February 25, 2008 I am experiencing the sticking ABS relay problem as described by others on this forum, such as here: http://www.ultimatesubaru.org/forum/showthread.php?t=81161&highlight=abs+relay It has occured just twice in 4-5 months, and a quick tap with a screwdriver stops it immediately. My question: Rather than buy a new relay ($$ is tight) is my relay repairable? I'm thinking that if it is just a simple mechanical problem, such as worn contacts, or something crudded-up, there may be a simple fix, especially since the relay is not totally bad. What do you think of fixing the relay? I know, the best thing to do is to buy a new relay. But $$ is tight, so it would be helpful to postone that outlay for awhile. Thanks, oh gurus! Quote Link to comment Share on other sites More sharing options...
EVOthis Posted February 25, 2008 Share Posted February 25, 2008 they are expensive your right about that...i called the dealership around me and they wanted $70 for one....... Quote Link to comment Share on other sites More sharing options...
idosubaru Posted February 25, 2008 Share Posted February 25, 2008 best bet is to get a used one. many people have access to parts cars or junk yards where these things are worth pocket change. post in the parts wanted forum or stop by a junk yard. you could try diassembling it and cleaning the contacts though. they are rather simple in design and function, though i've never taken one apart. Quote Link to comment Share on other sites More sharing options...
nipper Posted February 25, 2008 Share Posted February 25, 2008 If its already broken, you can't make it any worse. Try to clean the contacts. If not a used one will work. nipper Quote Link to comment Share on other sites More sharing options...
rude Posted February 26, 2008 Share Posted February 26, 2008 I was going to do the same thing last winter. In fact I still have them from my 95 Legacy. I had an ABS code (rear wheel sensor) and the pump turned on. I replaced the sensor and both relays (not sure if they were needed). I could sell you my old relays, as-is, for next to nothing. At least you could learn from opening yours up and use these in the mean time. They are working now, but hate to sell anything that I had a possible issue with. Rude (fighting the pack rat within) Quote Link to comment Share on other sites More sharing options...
ericem Posted February 27, 2008 Share Posted February 27, 2008 I had the same problem. I just took it out. Drenched it in contact cleaner. Then hit it a few times. So far has been a few years, and no abs relay sticking This better not jinx it Quote Link to comment Share on other sites More sharing options...
95LEGOBW Posted February 27, 2008 Author Share Posted February 27, 2008 Good advice: Always look for the siimple solution first! Contact cleaner - a great invention. Quote Link to comment Share on other sites More sharing options...
