XT6 Ohm testing specs since there is no manual available for XT6 and this ECU won't give codes.
Neither is true. The XT6 has a FSM nd the ECU will store/flash DTCs.
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Posted 17 April 2008 - 10:13 PM
Posted 18 April 2008 - 09:11 AM
Posted 18 April 2008 - 01:27 PM
In my case it is.Neither is true. The XT6 has a FSM nd the ECU will store/flash DTCs.
Posted 18 April 2008 - 05:01 PM
Posted 18 April 2008 - 05:47 PM
I'll see what I can find. Where in NE Ohio? Originally from the Warren/Youngstown area.
Posted 18 April 2008 - 08:34 PM
Posted 20 April 2008 - 10:02 PM
RMVR53, were you able to find a solution to this problem or able to find a replacement distributor (or CAS) or pickup coil?
I ask because I'm trying to diagnose an XT6 that had all of the same symptoms but with a much more rapid decline. It will no longer run at all.
I had a Toyota that had some similar issues until I replaced the pickup coil in the distributor and it's been running fine since so I've been searching for XT6 Ohm testing specs since there is no manual available for XT6 and this ECU won't give codes.
Posted 21 April 2008 - 11:59 AM
Posted 21 April 2008 - 01:02 PM
If the tach is still going wild after the disty replacement then I suggest you check the alternator as the source of the trouble.
Posted 21 April 2008 - 03:44 PM
Posted 28 May 2008 - 09:36 AM
Posted 29 May 2008 - 10:56 AM
ideas gang?
thanks
Bill
Posted 29 May 2008 - 03:28 PM
Posted 29 May 2008 - 07:50 PM
You should have the alternator checked out. I suspect it is causing the problem you see with the tach.
Posted 29 May 2008 - 07:55 PM
Posted 08 June 2008 - 05:41 PM
Excessive noise in the power buss can cause the low level signals from the sensors to be distorted and possibly intefer with the ECU also. If there is a power buss problem you possibly may be able to hear it in the AM radio tuned between stations.
Posted 09 June 2008 - 09:35 AM
Posted 09 June 2008 - 09:56 AM
After reading through the posts again I think you might have a faulty ECU. I suggest you try replacing that to see if it will get you going.
Posted 09 June 2008 - 11:33 AM
will a replacement have to come out of an 87 MPFI XT or what are my options?
thanks
Bill
Posted 09 June 2008 - 11:49 AM
87-91 4 cyl XT.
You might be able to use an ECU from a turbo GL. All the connections are the same, but it may not run quite right.
Posted 09 June 2008 - 12:26 PM
you sure on the years?..I not doubting you G, just funny how the brain stayed the same but they used a handfull of distributors that aren't interchangeable!!
Posted 09 June 2008 - 04:19 PM
Uhh..... As long as it's an optical style disty, it should be the same distributor for all 87+
Perhaps you have an early 87 xt. Does it have a vacuum advance diaphrahm on it? If so then you have the early style which would be the same as 85,86 MPFI/Turbo GLs. In that case you would need an ECU from one of those cars.
Posted 09 June 2008 - 05:14 PM
