It just quit on me the other day. I can bump start it (with help!) but don't have a wiring schematic. When I turn the key I get nothing, not even a click from a relay. I guessed it was the clutch safety switch on the clutch pedal assembly, but it looks like there are two of them. I replaced the lower one but that didn't help. At the top of the pedal assembly there appears to be another similar type of switch but that would be a pain to replace.
I disconnected the connectors from both switches and checked for power on both wires (for each connector) and get nothing when connected to a test light.
so:
1) Should there be power going to these connectors when the key is in the RUN position?
2) How difficult is it to replace the upper switch?
3) What else should I check?
I checked both fuse boxes and they all look fine. Battery has plenty of juice as well. HELP!!! thanks all!!
one switch may be for the cruise control.
the other the starter inhibitor
Both switches go "closed"
when the clutch pedal is depressed.
As a test, take the connector off the switch
and short the contacts with a paper clip
(better yet a short piece of wire with the
ends stripped.
See if this allows the car to crank.
If not you may have other issues
starter contacts
corroded bat cables/connections
ig switch going south
ect.
Hope this helps.
Ey ya go mate! I've a '94 too. One test might be put 'er in neutral set parking brake, if assistant available maybe have clutch held in, then put the key in run. Then using a jumper, apply +12V to the starter solenoid. If she cranks, the starter isn't the problem at least. If it doesn't crank, the starter may be having issues.
Get it on Porc!!!
You are the cat's meow when it comes
to
stepping up to the "here's the hot skinny" plate.
Rig:
As you can see the clutch switch need to be closed
to allow the "starter interlock relay" to engage,
thus providing power to the starter solenoid.
This interlock relay may be your problem
or the switch.
Shorting the switch will take it out of the loop.
(Thanks Porc, I have the same issue with my 94)
Thanks guys!! Turns out it was the upper of the 2 switches on the clutch pedal assembly. The lower one must be the cruise control switch, the upper being the clutch safety switch. I've got a jumper wire in there for now but will be ordering a replacement part shortly.
Thanks for the schematics & tips. Y'all ROCK!!!
