Weird whining noise (from AC) after engine is first shut off
4 replies to this topic
#1 Guest_HBDad_*
  • Guests
Posted 11 July 2003 - 12:17 PM
I own a 2003 LL Bean Subaru Outback. Anyway, I often get a weird whining noise (think Chewbacca from Star Wars) when I first shut off the car after a long drive with the Climate Control/Air Conditioning on. It lasts about 3 to 5 seconds and then goes away. Does anyone have any clue what this might be?
#2 Guest_Strakes_*
  • Guests
Posted 12 July 2003 - 04:22 PM
Could it be the cooling fan(s) that stays on after shutdown? I know that many times, mine stays on for a few seconds after shutdown. If that's it, then it's perfectly normal.
#3 Guest_1 Lucky Texan_*
  • Guests
Posted 12 July 2003 - 05:27 PM
If not the fans, maybe just a weird orifice tube/expansion valve issue as the pressure in the A/C system equalizes?
let us know when you find out OK?
1 Lucky Texan
#4 Guest_tomrhere_*
  • Guests
Posted 13 July 2003 - 05:34 AM
Could be pressure releasing from radiator cap too......Tom
#5 marinesgt
    New User
  • Pip
  • 1 posts
  • USA
Posted 20 September 2003 - 10:11 PM
I have a 2000 Outback 2.5 with the same issue. Good analogy by the way, Chewbacca. It happens when the ambient temp is above 85 degrees. It happens on up-pressure conditions, such as throttle lift-off at a stop light or passing gear acceleration or when it is above 90, when I turn the engine off. In the last example it will whine / groan for a good 15 - 30 seconds. Any ideas would be helpful. There is nothing on the Subaru tech site nor has the dealer found anything.
