Kostamojen Posted March 10, 2008 Share Posted March 10, 2008 I've noticed over the years that theres a slight issue with lifting Imprezas, the rear trailing link... The rear trailing length is X amount of length, so when you lift it, it rotates to the point where the rear tire starts to get close to the front of the rear fender as we know: The expensive solution is an adjustable length trailing arm... However, reading the last Subiesport issue, it was mentioned in an article by the "Team Orange" drift group that they use different rear trailing link BRACKETS to adjust handling on RWD imprezas. Brackets you say??? Yes, aparently the Foresters and some Legacy's have DIFFERENT brackets that mount the same but actually have LOWER trailing arm mounting points! BIGSKYWRX over on NASIOC lucked out and actually had one of these brackets laying around, heres the photo: As you can see, theres about an inch or so height difference on where the bolt to the trailing arm mounts to. This might not help 100% with the rear tire clearance issue, but it will help some, and those brackets can be found off of junkyard cars if you don't want to buy them new so ya, cheap option! Anyone want to try it out and post a picture of the results? Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted March 10, 2008 Share Posted March 10, 2008 Will the legacy outback brackets work on an impreza, or will we have to find Forestor brackets? Quote Link to comment Share on other sites More sharing options...
Kostamojen Posted March 13, 2008 Author Share Posted March 13, 2008 Will the legacy outback brackets work on an impreza, or will we have to find Forestor brackets? I honestly don't know which ones are which... I presume the 95-99 Outback brackets are like that as well, but I don't know for sure. Quote Link to comment Share on other sites More sharing options...
AlpineRaven Posted June 7, 2008 Share Posted June 7, 2008 So these brackets from Forresters are the same as Outback's brackets? Cheers AP Quote Link to comment Share on other sites More sharing options...
Gloyale Posted June 7, 2008 Share Posted June 7, 2008 If you look at the shape of that bracket you can see it's not hard to make one out of plate steel. We are making one with a 3 inch drop for a 4 inch lift right now. I haven't really been posting about it, but pics to come soon. Quote Link to comment Share on other sites More sharing options...
