Code P0446 and P0440
3 replies to this topic
#1 scottsheppard@videotron.ca
    New User
  • PipPipPip
  • 36 posts
  • Ottawa
Posted 15 March 2008 - 06:02 PM
Hello,
I have managed to pull the above noted codes...both at the same time (?)...I have read previous posts but would welcome any other ideas. Looks like a Vent Control Solenoid?
scott
#2 sea#3
sea#3
    Subaru Fanatic!
  • 354 posts
  • Vancouver Canada
Posted 16 March 2008 - 01:48 AM
You don't say what model and year ??????
SEA#3
#3 scottsheppard@videotron.ca
    New User
  • PipPipPip
  • 36 posts
  • Ottawa
Posted 16 March 2008 - 11:22 AM
SEA#3
Good point...that what happens when you spend too much time at the computer...car is a Legacy 2001 Wagon L.
cheers
scott
#4 sea#3
sea#3
    Subaru Fanatic!
  • 354 posts
  • Vancouver Canada
Posted 16 March 2008 - 08:41 PM
DTC P0440 — EVAPORATIVE EMISSION CONTROL SYSTEM
MALFUNCTION
 DTC DETECTING CONDITION:
 Two consecutive driving cycles with fault
 TROUBLE SYMPTOM:
 Gasoline smell
 There is a hole of more than 1.0 mm (0.04 in) dia. in evaporation system or fuel tank.
DTC P0446 — EVAPORATIVE EMISSION CONTROL SYSTEM VENT
CONTROL LOW INPUT
I would check the the vent valve connector first there maybe corrosion at the connector causing it not to operate and trip the P0440 code
The vent valve is under the lower right rear quarter panel , just above the carbon canister (black box )
For the leak you will want to check the gas cap for proper seal on the fill tube ,also check the carbon canister for any damage . Sometimes if you back into a snow pile that is iced up and crack the canister which causes a leak
Hope this helps
SEA#3
(PS the car is a manual transmission , right? )
