Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
T-case without 8+ inch lift?
#1
Posted 17 March 2008 - 12:24 AM
I've thought about the possibility of removing the front diff, cutting the casing out and welding in some blank off plates into the gearbox then sitting a diff up in that hole.
The reason I want this is so I can have RWD, good low range, and legal looking Subaru (any more then 2" lift is illegal and I'm sure if I ran 8" with 29" tires it would be defected instantaneously.
So, any ideas on how to get a t-case with no more then 4" lift? I reckon I could make a 4" look legal.
#2
Posted 17 March 2008 - 09:58 PM
That actually might be crazy enough to work.
The input shaft of the trans is pretty high in the case. YOu could eliminate alot of it. The drive pinion end would be exposed, Perhaps you could drive the T-case off of the drive pinion? Kinda backwards though. Finding the proper unit would be tough.
But then where would you're new front diff go???
#3
Posted 17 March 2008 - 10:23 PM
#4
Posted 18 March 2008 - 03:17 AM
#5
Posted 18 March 2008 - 04:04 AM
something like this:
I think Land Rover might have this setup, but I dont really know, all I know is that it exists and there is one like this in a junkyard near me
#6
Posted 18 March 2008 - 10:26 AM
I saw a vehicle once, it had 2 driveshafts comin off the t case toward the front, each one went to a mini differential at the wheel. I forget what kinda rig it was, but if you did it this way it would take extreme fab to make it work but i think it would be the best way, but you would have to take out the back seats to make the clearance for the T case in order to gain ground clearance
this one
#7
Posted 18 March 2008 - 10:35 AM
I to would like that, I realy like my white car with the 4" lift, it just needs a lower gear, I dont want it 8" up,
hummers have geared hubs
http://images.google...8JlcSaD1ixg3zPw
also the old 60s VW bus has this type hubs, $$$$$$$
#8
Posted 18 March 2008 - 10:37 AM
Yes yes exactly that! what kinda rig is that?this one
Those VW hubs would be awesome, talk about crawling, but how durable are they?
#9
Posted 18 March 2008 - 10:42 AM
#10
Posted 18 March 2008 - 10:47 AM
more vw hub ,, now the wheels would turn the wrong direction
#11
Posted 18 March 2008 - 10:51 AM
#12
Posted 18 March 2008 - 03:59 PM
Andy
#13
Posted 19 March 2008 - 07:01 AM
#14
Posted 19 March 2008 - 08:12 PM
Raising the engine up would probably be a good idea, to get as much room under it as possible.
Using an offset front diff would also probably mean using rear wheel drive as the primary drive, as I'm not sure the short-side axle would hold up to constant use. It would probably also require custom axles on the front, which is a pain when you break one.
Andy
#15
Posted 20 March 2008 - 04:18 PM
I was thinking of gutting the front differential out of the transaxle case, and then cutting away that area of the case to make more room for a different front differential unit (independent of the transaxle). The case would have to be closed back up by someone who can weld aluminum once the desired area has been cut away. It would be a lot of custom fabrication, to the transaxle case and the body's transmission tunnel.
Andy
different length axles is no problem, almost all cars with transverse mounted engines have them.
#16
Posted 20 March 2008 - 06:31 PM
The problem I came across with the VW portal hubs was they flip direction due to only two gears. And I just coldn't see how I could flip direction of drive in the gearbox or engine.also the old 60s VW bus has this type hubs, $$$$$$$
Although potal hubs would be almost the best option they still have a disadvantage of always being geared. So you either top out the speed at 80kph or run huge tyres which then loose all your gearing.
I'll have to look into that idea of moving then engine higher up then standard position and also think about using a different gearbox (maybe something from a nissan. Shorter the better I guess.
I would have no problem with cutting out some of the trans tunnel.
#17
Posted 21 March 2008 - 11:36 AM
So when you put a lift on, you lower the engine crossmember and you also put blocks for the engine mounts and tranny mounts to keep it at the stock height, mate the tranny to the T-case, run a drive shaft forward. hack out the front diff and get the housing modified so that a rear diff can rest in that area. Connect the front axles to the new rear diff and call it done.
Now the question is can Scott cast a modified tranny housing that has the front diff portion gone?
#18
Posted 21 March 2008 - 02:56 PM
#19
Posted 21 March 2008 - 08:33 PM
Hey scott i was wondering that too...can you or would it be feesable to cast front ea82 dual range case halves with the larger bellhousing of the ej case halves?
Hey now thats a interesting Idea, it could be done, there is some persise machine work inside that case, might be easier to modify the existing case and weld in a peice that I could make, that way there is no exacting machine work to do just some welding and seal the oil in,
you know what would be nice is a EJ belhousing with transfer case gears right behind
it with the transaxle dropped 4" lower then the engine , no center T-case and no 3 drivelines
#20
Posted 22 March 2008 - 09:46 AM
#21
Posted 10 April 2008 - 11:43 AM
#22
Posted 10 April 2008 - 03:37 PM
new thought, remove the stock transaxle and in its place back enough to allow the diff up in there hookup a transverse front wheel drive transaxle , weld up the diff spider gears in that transaxle and thats were the reduction would be it would be about a 4 to 1 as apposed to the 1.6 to 1 stock would be light and compact but require some big time machine work to hook it all up, or slip it in behind the stock transaxle for even lower gears, did I loose you??
I like it
#23
Posted 10 April 2008 - 06:27 PM
Problem is, that wouldn't allow onroad driving.
Plus keeping the Subaru box and a transfer case gives two low ranges.
I don't have any plans at the moment for anohter Subaru. But I would like to try this out one day.
