fuseable link questioin,
5 replies to this topic
#1 86subaru
86subaru
    Elite Master of the Subaru
  • 3,097 posts
  • ohio
Posted 25 March 2008 - 10:01 PM
would a bad fuseable link cause wipers to stop working, then a few miles down the road work fine, ? + rear wiper + cig lighter , or something else, ? thanks
#2 njdrsubaru
njdrsubaru
    is this thing on?
  • 1,198 posts
  • Old Bridge, NJ
Posted 25 March 2008 - 10:15 PM
there is a fuse inside the engines compartment fuse box that is for the dome lights, cig lighter, radio etc, that fuse got me by surprise, i did not know that fuse would control so many things... its just a regular fuse... i think a 20a
#3 Cougar
Cougar
  • 6,563 posts
  • Anchorage
Posted 26 March 2008 - 12:16 AM
Once a link goes bad it doesn't repair itself. They can have a intermittent connection though and cause things to work intermittently. Links carry a good amount of current and supply power to a lot of things tied to them.
#4 ivantruckman
ivantruckman
    4 inch lift
  • 956 posts
  • caro, MI.
Posted 26 March 2008 - 12:24 AM
intermittent problems are usally caused by a bad or corroded ground connection
#5 86subaru
86subaru
  • 3,097 posts
  • ohio
Posted 26 March 2008 - 05:49 AM
ok, i blew a fuseable link about a year ago, not thinking , i used one from a ea82 motor, and i can not remember the color or which place i put it in, also something else strange, my speedometer is working fine now, no bouncing around the fuel gauge is still reads less than whats in the tank, where is all the ground wires at, iam sure there is more than 1, . 95 legacy L awd a/t 2.2 motor,with 165,000mi on it,
#6 nipper
nipper
    Semi Elite Master of the
  • 18,195 posts
  • Long Island NY
Posted 26 March 2008 - 08:25 AM
Fuel tank is a subaru thing (and happens on other cars too). You need to remove the senders and clean them with a hard pencil eraser (tried a soft one, it didnt work),
The wiper can be a bad internal switch in the wiper motor, or a bad ground. Run a new grounbd for the motor and see if it works first, Of course there is the possability that you have it on intermitent.
nipper
