Rear EJ knuckle/hub assemblies interchange?
4 replies to this topic
#1 grossgary
grossgary
    Elite Master of the Subaru
  • 22,732 posts
  • East Coast
Posted 07 April 2008 - 12:35 AM
Looks like 2003 Impreza and 1997 Legacy rear hub assemblies/knuckles (entire hub, bearings, housing assembly) are interchangeable?
Does that mean the rear bearings and seals are all the same?
#2 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,809 posts
  • Houston, Tx
Posted 09 April 2008 - 06:21 PM
Possibly, but there may be superceeded parts on the newer hub.
#3 aircraft engineer
aircraft engineer
    Subaru Nut
  • 518 posts
  • close to Tacoma
Posted 09 April 2008 - 06:46 PM
the main thing to watch out for will be the ABS components on the newer unit and disc to drum issues. Backing plates bolt in directly (disc or drum - same bolts)
97 to 2003 drum to disc - The hub will have to come off anyway to install the disc backing plate because it has the ABS sensor
2003 to 97 - similar in reverse (will need to pull the hub to install the drum backing plate). If disc, I expect you still need to install the older backing plate, however, having no experience with that setup directly, I can't say for sure.
The 14mm backing plate bolts were on pretty tight (loctite on re-installation) I used an impact wrench on removal after I had pulled the hub out
Hub removal/reinstallation is not difficult IF you have a press.
8mm (might be 10 - I don't remember because I have a full set) flare nut wrench necessary for removal of the brake line at the wheel cylinder if drums.
#4 grossgary
grossgary
  • 22,732 posts
  • East Coast
Posted 09 April 2008 - 08:42 PM
CRACK.....i'm using the wrong terminology....are the entire rear knuckles interchangeable.
some to think of it i do know that they went to a different tone wheel set up on the rear disc ABS brakes. hmm...wonder if i can make that work?
thanks!
#5 aircraft engineer
aircraft engineer
    Subaru Nut
  • 518 posts
  • close to Tacoma
Posted 09 April 2008 - 08:46 PM
beats me - I can only tell you how to SWAP 'EM :grin:
