head gaskets? or maybe not?
7 replies to this topic
#1 subarubuddy
subarubuddy
    USMB Regular
  • PipPipPip
  • 59 posts
  • nyc
Posted 10 April 2008 - 09:10 AM
hi everyone.
i have a 92 loyale which has been sitting for about a year while i tried to find time and parts to do a rear disc swap.
the good news is its finally done.
bad news, it was hard to get it running and when it finally started there was lots of white smoke. (it ran fine and didn't smoke when i parked it last year)
i first thought head gaskets, but i'm not so sure.
i let it run for at least a 1/2 hour, no signs of overheating.
it also drives fine. runs pretty smoothly.
there's no oil in the coolant.
and no coolant in the oil.
is there anything else it might be? i haven't done a compression check yet and unfortunately i'm about 150 miles away from the car.
{edit} i forgot to mention: it smokes more at higher rpms. like when you rev the engine. doesn't seem to smoke more under load. smokes at idle too-just not as much.
#2 grossgary
grossgary
    Elite Master of the Subaru
  • 22,431 posts
  • Midatlantic
Posted 10 April 2008 - 09:21 AM
check all your signs and see what fluids you're loosing - should be oil or coolant.
could just be from sitting. how old is the gas - a year or more?
#3 Quidam
Quidam
    1000+ Super USER!
  • 1,622 posts
  • USA
Posted 10 April 2008 - 10:10 AM
Bingo. Not starting an engine for a year could be really bad in your climate.
Bore rust, for one.
#4 subarubuddy
subarubuddy
    USMB Regular
  • PipPipPip
  • 59 posts
  • nyc
Posted 10 April 2008 - 10:46 PM
yeah . the gas is about a year old. i guess i'll have to check compression and see what fluids dissappear when i drive a while.
#5 Andy FitzGibbon
Andy FitzGibbon
    Eat, Live, Breath Subaru
  • 335 posts
  • Elkins, WV
Posted 10 April 2008 - 11:05 PM
If the valve stem seals dried out from sitting they could be letting oil (small amounts) into the cylinders. If that's the case it will probably clear up with use. Keep an eye on all fluids, though. Probably not a bad idea to change the oil.
Andy
#6 john in KY
john in KY
    1000+ Super USER!
  • 1,505 posts
  • KY
Posted 11 April 2008 - 06:51 AM
Automatic? May want to check the vacuum modulator on the transmission.
#7 mdjdc
mdjdc
    1000+ Super USER!
  • 1,329 posts
  • Richmond
Posted 11 April 2008 - 11:16 AM
If the car sat for a long time the exhaust could have loaded up with poisture and that can take a long drive to get it all out. I've had this happen several times and after idling for several hours or a nice long drive the system cooked the moisture out and the smoking stopped never to return.
#8 subarubuddy
subarubuddy
    USMB Regular
  • PipPipPip
  • 59 posts
  • nyc
Posted 11 April 2008 - 02:36 PM
i actually thought of that too. and i hope so...but the car was smoking pretty bad as soon as i got it running. before the exhaust got hot.
