Full subaru drive train in mid engine rail?
Anomaly_983
Im batting around the idea of a mid engine offroad rail. If things go the way im liking them to it will be a two seater mid engine mid travel suspension. dose using the trans and engine from a subaru front wheel drive car. in a mid engine cofiguration. sound do-able?
Any ideas? or sugestions?
Its will be used on trails mudding and ocasionaly ( when the police are not looking) on the street.
sounds good I would go with the 4 x4 D/R trannny to get the lower gears and use EA82 axles
wold there be any complications for using a 4wheel drive tranny like that? is there a pic with measurements of mounting points? im new to the subaru game. but i know that they rock in motorsports and everone that has a air cooled vw dreams of a sube motor transplant.
the 4 wheel transmission will have an output on the rear of the transmission that will leak oil if there's no shaft in it. You can either put the first half of the first joint in there or be creative and fab something up ;)
Also, you cannot use the original gear linkages to control the Hi/Lo gearing, it will need some modding to use Hi/Lo in 2WD, but totally doable and I even believe there is a write up about it.
If you are going to use an EJ series engine, you will need an adaptor plate and be creative with the clutch/flywheel. Again, there is loads of information on this on the board and it is not going to pose a problem :)
