is it possible for 5 speed swap in gen 1
5 replies to this topic
#1 nevbrat
nevbrat
    New User
  • PipPip
  • 16 posts
  • las vegas
Posted 16 April 2008 - 08:08 PM
has anyone done the 5 speed swap with gen 1 ? is it worth it. my top speed is like 65 mph in my 78 brat i just bought.
#2 The Beast I Drive
The Beast I Drive
    CALL ME, (509) 391-5903
  • 2,120 posts
  • Toppenish, WA
Posted 16 April 2008 - 08:44 PM
5 speed d/r, or 2wd? the dual range you will need a lift or some custom metal work on the trans tunnel or it wont fit. Also you would need a fat case EA71 ebgine bellhousing or a modified(?) EA81 engine bellhousing for the trans to mount to the motor, as well as custom tranny crossmember, driveshaft, and linkage. Doing a 5 speed/EA81 swap in a 80 Brat right now, 3 inch lift in the front, 6+ in the rear.
The 2wd 5 speed was available in that body style, would be a bolt in I would imagine, you'd just have to dump the rear 4wd stuff.
#3 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,931 posts
  • Portland
Posted 17 April 2008 - 08:49 PM
That has nothing to do with your transmission. You have not yet learned the ways of the EA engine. I could easily do 90-100 in every 4 speed I've owned. You have much to learn, and a lot of repair/tuning to do.
#4 carfreak85
carfreak85
    Temple of Fuji
  • 5,299 posts
  • Cascadia
Posted 09 May 2008 - 02:29 AM
I've got the appropriate car sans engine and tranny as well as the transmission in question. I could try slipping them together this weekend. Hmmmm, ideas just came to my head.... :popcorn:
#5 stumpy
stumpy
    Eat, Live, Breath Subaru
  • 310 posts
  • Bridal Veil
Posted 09 May 2008 - 11:45 AM
How much of a lift is required to get this to fit?
Thinking about doing this to mine but don't want to go any higher than necessary.
#6 82bratavenger
82bratavenger
    USMB Regular
  • PipPipPip
  • 109 posts
  • Malaga, WA
Posted 09 May 2008 - 11:35 PM
I have fit an EA81 with 4 spd d/r into my old 79 wagon. It did however require some creativity. The 4x4 shift leaver was tricky but a little tweek here and a bend there and a few modifies parts and it is a scream'n machine. Sold it to a friend a couple of years ago and it is now over 450,000 mi. All he does is change the oil and put gas in it. I love the EA motor. GD is right, before I did the swap I had it over 100mph several times with the old EA71 stock set-up. Why else would they come stock with a speedometer that goes up to 140 mph :grin: It is not a transmission problem.
