95 Legacy P0325 and P0106 related?
6 replies to this topic
#1 AEROCOOK
AEROCOOK
    New User
  • PipPipPip
  • 57 posts
Posted 21 April 2008 - 06:29 PM
My CEL has been on for a while and the fuel economy has gone down the tubes. I pulled codes P0325 and P0106 out which I believe are knock sensor and MAP sensor respectively. Is it possible that these 2 codes are related? If the knock sensor fails I understand that the ECU will retard the timing to protect the engine from detonation, Is it possible that this can affect the MAP sensor at all? Also, I just want to confirm the location of the MAP sensor it's on the manifold pass. side has 3 wires identified with ABC right?
#2 EVOthis
EVOthis
    1000+ Super USER!
  • 1,392 posts
  • Kennett Square PA
Posted 21 April 2008 - 06:34 PM
the MAP sensor is located on the passangers side shock tower ( at least it is on my 96' Legacy).....i dont believe they would be related (but lord knows electricity does some weird stuff)......did both of the codes set at the same time? I also believe that the knock sensors on this year/model are prone to cracking on the side that contacts the block......
#3 AEROCOOK
AEROCOOK
    New User
  • PipPipPip
  • 57 posts
Posted 21 April 2008 - 06:55 PM
Yes, it seems knock sensor failure is common on Subarus of this vintage and I have one on order. As for the MAP sensor, what does yours look like? I have looked at everything on the pass side strut tower but not really sure what Im looking for. The item that I thought was the MAP sensor is bolted directly to the manifold is kind of cylindrical in shape with a grey adjustable cap on top.
#4 aircraft engineer
aircraft engineer
    Subaru Nut
  • 518 posts
  • close to Tacoma
Posted 21 April 2008 - 07:45 PM
http://www.ultimates...99&d=1208455598
it's a "rusty" one but it's a pic - pax side shock tower - the car was supposed to be a 95
#5 AEROCOOK
AEROCOOK
    New User
  • PipPipPip
  • 57 posts
Posted 21 April 2008 - 09:09 PM
Thank you, I do recall seeing that part and I really appreciate your effort to find and post the picture. I live in Ontario and the old Legacy has to pass an emmisions test by June or she's off the road. I initially ruled out that part because I thought I read that the MAP sensor had 3 wires.
Going to replace knock sensor this week and see if the light comes back on.
#6 AEROCOOK
AEROCOOK
    New User
  • PipPipPip
  • 57 posts
Posted 28 April 2008 - 10:10 AM
Can anyone provide the torque spec for the knock sensor?
#7 OB99W
OB99W
    Elite Master of the Subaru
  • 3,315 posts
  • Ithaca
Posted 28 April 2008 - 10:51 AM
Here you go: http://endwrench.com.../1995Subaru.pdf
Better to be on the low than the high side of the spec.
