roque43 Posted December 28, 2003 Share Posted December 28, 2003 Are there any special things I need to know or do to engine / trans as far as maintenance is concerned. A bit of history on the car -- inherited from my Mom after her passing on. has about 135,000 miles on it, was maintained by the original selling dealer. Sat for about 7 years after her passing. I got it running after turning over by hand to make sure it was not stuck. new battery, fresh gas and it started pretty well. runs great -- purrs like a kitten. I did notice a couple of things -- turn sigs are not working, and the "trip computer" is dead -- any ideas? Thanks Quote Link to comment Share on other sites More sharing options...
dj72 Posted December 28, 2003 Share Posted December 28, 2003 Have you checked all the fuses to make sure none are blown? Try that first. Quote Link to comment Share on other sites More sharing options...
Skip Posted December 28, 2003 Share Posted December 28, 2003 roque43, Dean is correct check your fuses first trip pooter - fuses #5 and #12 t.s. - fuse # 10 My check mark goes beside a bad flasher unit. As for maintance items, timing belts may be first on your list They should be changed at 60 kmi, you may be lucky in so much they may have been changed but... sitting for that long may have dried them out - some rubber like products (tires for instance) need to be "exersized" to keep their pliability. You may want to pull a cover for a peek. Note: no engine damage will result if one breaks as these are non-interference engines. The normal fluid changes are in order - please do not forget the brake fluid - it could have absorbed moisture over the years. Hope this helps Quote Link to comment Share on other sites More sharing options...
rallyruss Posted December 28, 2003 Share Posted December 28, 2003 I would say that the cooling system( radiator, hoses, T stat, fan Ect) are verry improtant items on these cars as they do not react well to overheating. head gaskes blow out and cracks are common on the heads evin with no overheating. Quote Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted December 28, 2003 Share Posted December 28, 2003 Dont worry about the trip computer not working. Everytime I disconnected the battery on my turbowagons I would lose it until it was able to think for afew miles. Quote Link to comment Share on other sites More sharing options...
