danbennett2u Posted May 5, 2008 Share Posted May 5, 2008 I am searching for replacement front brake pads for my 93 Legacy, and want to know if pads listed for dual piston calipers will fit on a single piston caliper. I ask because there are dual piston ceramic pads displayed for a Legacy L on rockauto.com even though the post below says they are mainly on turbos. Since they are almost the same price as semi-metallic single piston pads it would be great if they are interchangeable! http://www.ultimatesubaru.org/forum/showthread.php?t=76707 Quote Link to comment Share on other sites More sharing options...
jamal Posted May 5, 2008 Share Posted May 5, 2008 If you go down to the bottom of that post, it shows the d-plate numbers for 1-pots and 2-pots depending on year. They are not the same. No Legacy L had 2-pots until like 2000. however, I think I read somewhere that a guy had put a 1-pot caliper on a 2-pot bracket. So maybe they'll fit, but I doubt it. I'm pretty sure you can get Hawk HPS or EBC yellowstuff for a 93 legacy, which are both good. I ditched my stock brakes awhile ago. Quote Link to comment Share on other sites More sharing options...
Reveeen Posted May 5, 2008 Share Posted May 5, 2008 I have a '91 Turbo, and I can attest to the fact that it does not use/require the "normal" pads, I always have to order, and wait about 10 days to get them, while the "normal" pads are a stocking shelf item. Quote Link to comment Share on other sites More sharing options...
