Fog lights not working
1 reply to this topic
#1 Guest_giboufou_*
  • Guests
Posted 09 July 2003 - 06:08 AM
Hi All,
98 Legacy Outback 2.5L
Fog lights don't work... Changed bulbs, fuse is ok (unless there is another one I don't know about), the light on the switch does not come on either, contacts are clean.. Are there other components in the circuit that can short out?
I think the original ones blew when rocks cracked the light assembly and probably let water in.
#2 Guest_Commuter_*
  • Guests
Posted 09 July 2003 - 11:50 AM
Make sure your headlights are not set to high beam. The fogs are turned off if you have your high beams on.
