cylinder not working on a 96 Outback 2.5 L
Guest roastbeefalo
Here is what I know about the problem with my 1996 Subaru Outback Legacy wagon 2.5 L 4 cylinder with 180000 miles
The rear left cylinder, looking from the front, is not working. I replaced all 4 plugs (Not the plugs). I swapped out wires with the front left cylinder and it was still the rear left cylinder not working (Not the wires). I can see a spark from the coil on top of the engine (Not the coil). I then put some fuel injector cleaner in the gas and drove 200 miles, with no difference. I pulled the new plug out of the bad cylinder, and it was all black. I noticed that my gas mileage went up after the cylinder went out; from 22 mpg to 26 mpg (I keep track of it on every tank of gas). The generic Autozone computer read my check engine light as a cylinder 3 misfire. I listened to the fuel injector by placing a screwdriver on it and it ticked just like the other 3.
I think it may be the fuel injector or I lost compression (I need to find someone to check the compression for me).
Any ideas? Any diagnostic tips? Is it worth doing the job if it is the compression (my gut says yes)?
Guest Legacy777
pull the cap off the injector for that cylinder, and see if the car runs worse or not. Next check compression on that cylinder. If compression is good, and pulling the plug off the injector doesn't really change how the engine runs, I'd say it's a bad injector.
Guest ShawnW
Time to get the hands dirty. If you think you are going to replace a head gasket yourself then you should probably be looking into buying an inexpensive compression tester or getting a loaner one from a parts store.
Do you have Spark on that perticular plug? The fact that you have 26 MPG on that motor is pretty amazing.
Guest roastbeefalo
I went ahead and took the cap off the fuel injector, and it did not change the performance as far as I can tell. I hope to find out about the compression soon, I wonder how much the required tools cost?
Guest 1 Lucky Texan
Sometimes you can rent a tester from a parts shop. You just jam it in the spark plug hole and hold it in place for a copupla revolutions. It should have a needle to record the highest number.
Curiously, and old trick to help determine compression loss due to bad rings vs. valve problems may not work on Subaru engines!
The idea is to get a compresion number - lets say its 70psi - then you would squirt/pour in a coupla teaspoons of oil - maybe even some STP - and then do another test immediately. If the number was a lot higher, approaching normal, then the oil soaked rings were sealing and it indicated bad rings. If the valve were burned/stuck open, you'd get about the same number. I don't know how this could be done with a horizontal cylinder. maybe some type of spray nozzle? maybe a tech guy will chime in.
good luck
Carl
1 Lucky Texan
