My new project : BRAT
24 replies to this topic
#1 lumpycam
lumpycam
    USMB is life!
  • 210 posts
  • Newport , WA
Posted 24 May 2008 - 07:02 PM
Hi all, I finally found a good gen1 brat to have as my newest project. I bought a gen2 last fall and found it to be too rusted.So i've been looking for another body to use with my frankenmotor (2.5 w/2.2 heads).
My freind who owns the local wrecking yard saved it for me.It's a 1978 and has ea81 and d/r4spd partially installed.Someone seen fit to paint the body wth bedliner,thats gonna be fun to remove for new paint. My plan is too build it into a rwd street brat. I have a ej25 high comp motor with delta 230 cams and ported heads joined w/ 5spd ej trans converted to rwd.The rear end will be 4.44 lsd with 225/50/15 on six lug wheels.
Should be able to do all three D's with this one (drivin,draggin and driftin)Posted Image
http://good-times.we...host=good-times
#2 lumpycam
lumpycam
    USMB is life!
  • 210 posts
  • Newport , WA
Posted 24 May 2008 - 07:10 PM
Here a bigger pic!
Posted Image
#3 Crabman
Crabman
    USMB is life!
  • 194 posts
  • 90278
Posted 24 May 2008 - 10:20 PM
Wow nice Gen 1 score! Have fun with your new project.
#4 kiwi subbie
kiwi subbie
    Certified Subaru Nut
  • 932 posts
  • Christchurch, New Zealand
Posted 25 May 2008 - 01:31 AM
its be 1 sweet project your doing there:grin:
#5 Spiffy
Spiffy
    this road's wide enough
  • 978 posts
  • Portland, OR
Posted 25 May 2008 - 02:00 AM
with a 2.5 and that light rear end you'll see more driftin' miles than straight... drift on!
--Spiffy
#6 waimaks
waimaks
    Hey Boe!
  • 719 posts
  • NZ
Posted 25 May 2008 - 06:30 AM
I like the way you think :headbang:
Full write-up as you progress please!
#7 lumpycam
lumpycam
    USMB is life!
  • 210 posts
  • Newport , WA
Posted 25 May 2008 - 07:55 PM
Here's Day two progress ! Got rained out or would've had whole car sanded.Installed the 6 lug hubs and wheels.removed all trim and bad sheetmetal. Not too bad for one day into the build.
Before :
Posted Image
AFTER :
Posted Image
Posted Image
Posted Image
#8 lumpycam
lumpycam
    USMB is life!
  • 210 posts
  • Newport , WA
Posted 25 May 2008 - 08:01 PM
This is the '85 Brat that I was building until I found too much rust to continue.I was setting it up with 295/50/15 tires on the rear, too bad would've been cool!:(
Posted Image
#9 Flowmastered87GL
Flowmastered87GL
    WCSS Drunk
  • 6,273 posts
  • Portland, Oregon
Posted 25 May 2008 - 08:17 PM
Posted Image
Wow that woulda been so sweet with those big fatty tires in the rear.... which I assume it could still melt into rubber streaks :headbang:
#10 Crabman
Crabman
    USMB is life!
  • 194 posts
  • 90278
Posted 25 May 2008 - 10:20 PM
Lumpycam,
The amount of progress you've made after just two days is superhuman. :eek: Looks like you be done in a week and a half? :lol:
I have to ask, where was the rust that made you quit on the 85?
Keep up the good work,
Crabman
#11 lumpycam
lumpycam
    USMB is life!
  • 210 posts
  • Newport , WA
Posted 25 May 2008 - 11:06 PM
The rear quarter panels mostly, some 10 pounds of sand fell out when I was removing rearend. The rockers are going and the innner bed sides have big holes. The car came from the oregon coast and must have seen lots to beach duty. The rest of the car was pretty good shape except were the frontend had been crudely repaired from a collision. It will make good parts for my next gen II brat when ever I find another.
#12 joostvdw
joostvdw
    Subaru Nut
  • 609 posts
  • Holland
Posted 27 May 2008 - 02:17 PM
Why aren't you still going with the fatty tires? They look awesome and so does the paintjob!
#13 lumpycam
lumpycam
    USMB is life!
  • 210 posts
  • Newport , WA
Posted 27 May 2008 - 03:29 PM
To answer your ? is I'm not building the '85 anymore since I found the '78.
I may pro-street the '78 at a later time , I want to get it together and drive it as quick as possible.Narrowing the rearend is a major job ,taking more time than I want to spend right now. Although It would look really COOL!!!!
Day Three:
Not much progress, I did spend time locating parts i need.I decided to put rear disk brakes and ea81 vented front brakes on.I figured a little more WHOA! to go with all the GO! was needed.
#14 lumpycam
lumpycam
    USMB is life!
  • 210 posts
  • Newport , WA
Posted 03 July 2008 - 10:45 PM
Finally making some progress again. I installed a used ej22 and 5mt to mock up mounts and rad.I also stripped wiring harness and made it run with key. Installed the ej rad with dual fans.Modified trans crossmember to accept ej trans.removed engine and trans to clean and paint engine bay.Installed rear lsd and rear disk brakes.changed steering rack and entire front suspension for good used stuff.Also installed vented front brakes and parking cables.changed wheels from alum to steel rallye , front ea82 spare and chevy truck 15x8 rear. put 225/50/15 cobras on rear and continental 155/60/15 on front. I also made and installed short axle on front. The driveline was sent in to driveline shop and is ready for pickup .
I still need to make head gaskets for ej25/22 combo and assemble them on engine.The center diff in trans needs to be removed and welded to rwd. And take note of this :
To install ej trans in ea71 , the bottom drivers bellhousing bolt must be shortened about 1".The rag joint and bolts hit the bolt and nut ,will not allow turning of steering.I tryed positioning the engine in different ways but still could not escape the problem.My solution is to remove a corner of bellhousing and using a shorter stud. You could also counter sink bolt hole in trans and use a socket head bolt.
Lot's left to do !!! getting really excited to get the ej25 in and here it run. Later.......
#15 newsoobdude
newsoobdude
    Subaru Nut
  • 645 posts
  • helL A/ NorCal Foothills
Posted 04 July 2008 - 02:32 AM
pics?
#16 Zefy
Zefy
    1000+ Super USER!
  • 1,171 posts
  • Coquitlam B.C. Canada
Posted 04 July 2008 - 02:56 AM
i am having the same issue with mine however i opted to modify the steering rather than the bellhousing. if you remove the rag joint entirely and weld a rod in place then cut off the 'ears' with the studs on the steering than you're in the clear.
#17 lumpycam
lumpycam
    USMB is life!
  • 210 posts
  • Newport , WA
Posted 11 July 2008 - 01:05 AM
Here's a few teaser pics of whats to come ! I got the engine assembled and thought you might want a peek. Sorry for crappy pics from my Wmart $19.00 digi cam.
Posted ImagePosted ImagePosted Image
http://www.ultimates...=500&ppuser=659
#18 kiwi subbie
kiwi subbie
  • 932 posts
Posted 11 July 2008 - 04:20 AM
ooooh shiny red cam pulleys :grin:
#19 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,194 posts
  • WA
Posted 11 July 2008 - 11:40 AM
Are you coming to WCSS10 this year?
And if so, are you bringing the Brat? ;)
#20 lumpycam
lumpycam
    USMB is life!
  • 210 posts
  • Newport , WA
Posted 12 July 2008 - 09:50 PM
I want to make it the show it depends on if I get the brat finished.So to aswer you, Yes and yes.
#21 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,194 posts
  • WA
Posted 14 July 2008 - 10:34 AM
Well, get r done!
I've have 3 cars to get ready, you only have 1! :-p
#22 subyrally
subyrally
    Trust your Turbo-Lust
  • 2,893 posts
  • frederick, md
Posted 21 July 2008 - 04:17 PM
this thread needs more pictures.:lol:
#23 michael appel
michael appel
  • 779 posts
  • wilsonville Or
Posted 21 July 2008 - 06:20 PM
Nice pics
#24 lumpycam
lumpycam
    USMB is life!
  • 210 posts
  • Newport , WA
Posted 15 August 2008 - 05:01 PM
I manage to get the brat together enough to drive temporarily. I won't be able to make it to wcss10 due to stupid head cold that put be behind at work. The brat also didn't get finished enough to drive it across state.I will miss seeing everyone and all the cool suby's. However I have been ripping around locally in the brat and am enjoying the power of the ej motor. Here's a pic of the dual headers I had built for it. Enjoy!!:)Posted Image
#25 kiwi subbie
kiwi subbie
  • 932 posts
Posted 16 August 2008 - 03:47 AM
thatz looks good
