What does this do?
I have just began wiring up my leone sedan tail lights onto my hatch and have find an unusual coil mounted near the wiring on one of the lights.
It is situated behind the plastic pannel which holds in the glodes. A pic can be seen at the link below. Where you will see the coil on the right hand side of the holder.
http://community.webshots.com/photo/103615033/107630091cqdxox
What does this do? And do i need it?
Thanks guys
Dave
Upon further investigation and some posting on other forums, i have found that it is infact the break light warning system that turns the break light on in the dash if a glob blows. Thanks everyone for your help. I was a little confused because the wagons and the hatch i have both have a seperate unit located in the rear fender which did this.
Thanks again
Dave
If I remove the stop lamp checker (un-plug), will it mess anything up?
I want to remove as much usless wiring as I can. This one has 6 wires attached to it.
If I get rid of this will the dash light be on?
Thanks,
Glenn
82 Summer, almost wired.......
01 Forester, bent but not broken........
