91 Legacy 4" lift Build
43 replies to this topic
#26 Scott in Bellingham
Scott in Bellingham
    Lets go wheelin!!
  • 4,045 posts
  • Bellingham
Posted 20 June 2008 - 01:33 AM
Scott, do me a favor and measure the rear diff clearence on a flat surface or me. I am just trying to compare to my 90 leg wagon with 2" blocks and OB springs.
Sorry to hi-jack, Thanks.
Looks good!
Todd
got 11" at the Diff
#27 Scott in Bellingham
Scott in Bellingham
    Lets go wheelin!!
  • 4,045 posts
  • Bellingham
Posted 20 June 2008 - 01:38 AM
That's looking sweet:clap: . Do you think you could build it with the 4 inch strut extentions but use maybe 2, 2.5, or 3 inches for the blocks, depending on what the axles and cv's can handle, .
this is with 4 1/4 "at the wheel and 3" at the diff , your right it may take greater angles, I want something reliable and this is 1" over stock, and the front will still have less clearance then the back
#28 ezapar
ezapar
    [OTD]
  • Moderator
  • 27,367 posts
  • Seattle
Posted 20 June 2008 - 11:00 AM
Its just a suggestion you might look into because its always nice to have more clearance under the diffs.
Indeed. But the y-pipes have to clear everything first. There's really no need to have the rear diff any higher than the y-pipes. 11 inches ought to do it Scott. Looks baddass!
#29 Gloyale
Gloyale
    It's a sickness
  • 10,643 posts
  • Corvallis, OR PNW
Posted 06 July 2008 - 10:21 PM
Legacies ussually sit higher under the pan and y-pipe than at the rear diff, espescially if there is any weight in it.
Scott, any progress on the lift? I am dying to see:slobber: You can't let me be the only one at WCSS with a lifted, Legacy. (ridiculously sick, big, divorced transfer, full frame monster wagons excluded)
#30 Scott in Bellingham
Scott in Bellingham
    Lets go wheelin!!
  • 4,045 posts
  • Bellingham
Posted 07 July 2008 - 12:15 AM
no I got swamped with orders and its been sitting the backs all done, and yes I hope to have it at the show
#31 Gloyale
Gloyale
    It's a sickness
  • 10,643 posts
  • Corvallis, OR PNW
Posted 07 July 2008 - 01:12 PM
Sweet.
#32 Scott in Bellingham
Scott in Bellingham
    Lets go wheelin!!
  • 4,045 posts
  • Bellingham
Posted 25 July 2008 - 07:58 AM
Backs all done, ended up adding 4-1/4 " lift in the rear ,
Posted Image
Posted Image
maybe I should just leave it like this Huuuuuuummmm:rolleyes:
looks like tonight and tommarrow will be liftin the front if your in the area I could use some help ,
#33 Scott in Bellingham
Scott in Bellingham
    Lets go wheelin!!
  • 4,045 posts
  • Bellingham
Posted 26 July 2008 - 01:14 AM
got the front underneath all done, now to do the strut extensions and and the steering knuckle
Posted Image
#34 Scott in Bellingham
Scott in Bellingham
    Lets go wheelin!!
  • 4,045 posts
  • Bellingham
Posted 27 July 2008 - 01:33 AM
lifts all in
Posted Image
Posted Image
Posted Image
#35 Syn
Syn
    New User
  • Pip
  • 7 posts
  • Renton
Posted 27 July 2008 - 02:47 AM
Wow that looks nice!
#36 The Scooby
The Scooby
    EJ Swap Junkie
  • 1,752 posts
  • South Seattle
Posted 27 July 2008 - 09:50 AM
nice work. i like how innovative you are with your work.
#37 ezapar
ezapar
    [OTD]
  • Moderator
  • 27,367 posts
  • Seattle
Posted 27 July 2008 - 10:21 AM
Very nice Scott! Now you get to cut and cut and cut to make those bad boys quit rubbing eh?
Those wheels worked out great.
#38 one eye
one eye
    I'm A Subaholic
  • 2,593 posts
  • Mt.Vernon Washington
Posted 27 July 2008 - 05:21 PM
Wow, Scott that looks very nice. I though you where going to use those black steel wheels but those Aluminum ones really look good on it.
Are you really going to wheel it though? looks kinda pretty really nice.
Jeff
#39 michael appel
michael appel
    Certified Subaru Nut
  • 779 posts
  • wilsonville Or
Posted 27 July 2008 - 08:49 PM
Sweet job scott
#40 newsoobdude
newsoobdude
    Subaru Nut
  • 645 posts
  • helL A/ NorCal Foothills
Posted 27 July 2008 - 10:34 PM
lifts all in
Posted Image
Posted Image
Posted Image
:slobber: :slobber: :slobber: . NICE!!!!!!!!!! Add a little sawzall work to the 'wells and it'd be perfect. Rock on:headbang:
#41 Scott in Bellingham
Scott in Bellingham
    Lets go wheelin!!
  • 4,045 posts
  • Bellingham
Posted 28 July 2008 - 11:30 AM
Jeff
thats why I built it , will hit the dunes first
#42 TeamCF
TeamCF
    Rocker panel smasher
  • 1,271 posts
  • Sandy, OR
Posted 28 July 2008 - 12:53 PM
:slobber: :headbang: :burnout:
Nice. That'll turn some heads on the freeway.
Can't wait to see it in the sand. Proly gonna get alot more confused looks from the ATV'ers than I did when I was there. :banana:
#43 Scott in Bellingham
Scott in Bellingham
    Lets go wheelin!!
  • 4,045 posts
  • Bellingham
Posted 06 August 2008 - 11:48 AM
I really Love this car, Its awesome, couple things I will be changing is on the rear I went straight up with the lift blocks, well the rear tire sits closer to the front edge near the door , the wheel isnt centered in the opening, this causes the rear tires to rub on the seat belt bolt stud when you hit a big bump, I will be replacing those blocks with holes more toward the rear ,also its easier to trim the rear plastic bumper instead of the steel near the door , also the front has more camber then I want, I will be changing that on the next set of extentions which will fix that,
#44 mellow65
mellow65
    Subaru, my drug of choice
  • 1,086 posts
  • Portland
Posted 06 August 2008 - 12:12 PM
check this out for an option about the trailing arm bracket.
http://www.ultimates...ead.php?t=86178
