Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
92 Legacy AWD Trans issue
Started by
covrace
, Jun 02 2008 06:40 PM
6 replies to this topic
#1
Posted 02 June 2008 - 06:40 PM
Hey gang. I'm looking at a 92 legacy with awd. Owner stated "something in the trans is wrong. Trans is fine straight but when turned, the car shakes like it has a locker. Any ideas, is this serious or just a simple adjustment. Says the cars great but has this issue.
Thanks in advance.
Jake
Thanks in advance.
Jake
#2
Posted 02 June 2008 - 06:42 PM
could be torque bind.....is this a manual trans or automatic?...either way do a search for "torque bind" or look down the bottom of this thread for the related posts.....how many miles?
#3
Posted 02 June 2008 - 08:18 PM
the car is an automatic with 135000 on the clock. I've experienced this sort of thing before but that was on my 85 audi quattro with vaccuum operated locking diffs front and rear( and you guys thought your subbs were great in snow?)
thanks again
Jake
thanks again
Jake
#4
Posted 02 June 2008 - 09:34 PM
Put a fuse in the FWD holder under then hood on the passenger size near the firewall. It will disable the four wheel drive.
That way you'll know if it the AWD or the trans.
#5
Posted 03 June 2008 - 08:09 PM
could always try changing the auto. trans fluid..... and with the new fluid add an additive/conditioner (i have heard that this works in some cases)....
#6
Posted 04 June 2008 - 05:12 PM
So if FWD fuse in holder (what size fuse to use?) and it still shudders is that tranny issue? If tranny issue is it clutch pack or something easier to fix?
#7
Posted 04 June 2008 - 06:00 PM
The "proper" operation of the center differential requires an electrical signal to be generated in the TCM (transmission control module beside the steering collum) and make it's way, down a wire, through several connectors, to what is called the "duty C" solenoid, inside the transmission. This "duty C" solenoid switches on, and off, as required, to apply hydraulic pressure, as needed, to the clutch pack inside the transmission, that makes up your center differential unit.
It is one of those things that you can spend a lot of time properly diagnosing just EXACTLY what the problem is. I have it on good authority that pin #3 at the TCM connector should show 9-15 ohms to ground (the resistance of the duty C solenoid) , this would eliminate most of the potential electrical problem (excepting the TCM), and once you eliminate the TCM (by substitution), you are indeed looking at a transmission "issue".
In an older car, issues such as this are tough to track down, many times you can spend more time "tracking" than "fixing".
