Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
5 speed swap
#1
Posted 07 June 2008 - 11:09 PM
#2
Posted 07 June 2008 - 11:42 PM
http://www.ultimates...ead.php?t=52234
http://www.ultimates...ead.php?t=11762
#3
Posted 08 June 2008 - 01:50 PM
http://ultimatesubar...ead.php?t=69534
Hope that answers all questions.
#4
Posted 08 June 2008 - 02:14 PM
i'm not sure if it matters but a 3AT verses a 4EAT auto (both offered in EA82's) might make a difference? might want to post what vehicle and/or trans you have now.
#5
Posted 08 June 2008 - 08:00 PM
#6
Posted 08 June 2008 - 09:18 PM
I've discovered trans fluid in the front differential and I assume its a failed seal that i've read about on the forum elsewhere.
1. Those rarely fail.
2. Have you drained it and filled it with the proper respective fluids and made sure it wasn't just a mistake by a previous owner and/or shop?
3. Trans fluid in the front diff won't neccesarily hurt it for quite a while. You may get 10's of thousands of miles out of it before the front diff goes. Many of us run ATF in our manual transmissions (same front diff style) on purpose in order to clean/renew the syncro's. It's not detrimental to their life in a big way.
4. If/when you do the swap, it's simple. Pedal assembly (4 bolts, and some cables/brake rod), clutch/cable/flywheel, front section of the driveline, rear end if you need it (ratio change?), cross-member, shift linkage, jumper two pins on the 3AT harness for the crank circuit, and install interior consoles.
#7
Posted 08 June 2008 - 10:40 PM
does he have to do the wiring for the reverse lights to work?
you might need the starter too?
it's really nice to do this swap using a parts car. keep your eye out, they aren't hard to find really cheap or free.
#8
Posted 09 June 2008 - 12:30 AM
Yeah - if he wants them he'll have to find the reverse switch on the tranny and run wires to the old 3AT connector. Not a huge deal though.
Nope.
Always best that way, but the 4WD 3AT to 4WD 5 speed is about as simple as they get. Probably only two or three trips to the junk yard
#9
Posted 09 June 2008 - 07:34 AM
MAAHAHHAAA!!!!! awesome morning laugh!Probably only two or three trips to the junk yard
