Valve Cover Replacement ?
5 replies to this topic
#1 elmwood22
elmwood22
    USMB Regular
  • PipPipPip
  • 76 posts
  • Deerwood
Posted 11 June 2008 - 03:46 PM
Haven't done a whole lot of searching but.......is there a trick when replacing the valve covers on a '95 2.2L? Upfront it looks pretty straight forward especially the passenger side, but on the driverside it looks like the oil dip stick housing may cause a problem, em, em, not a problem but make it a little more complex. (Possibly mistaken, I have been before) Also, what type of gasket sealant would be recommended if any. Grommets, a yes? Just trying to take care of the seepage.
Thanks.
#2 monk50
monk50
    USMB Regular
  • PipPipPip
  • 89 posts
  • Albemarle, NC
Posted 11 June 2008 - 04:31 PM
Thanks.
Not a big problem on the drivers side. You are correct, remove the oil filler tube, 2 screws, may want to put a rag in the opening until you replace the tube. You can then get to the valve cover. Others remove the the battery also for a little more room.
monk50
#3 EVOthis
EVOthis
    1000+ Super USER!
  • 1,392 posts
  • Kennett Square PA
Posted 11 June 2008 - 05:59 PM
dont use any gasket sealant..new valve cover gaskets do wonders....i just replaced them on my 96 2.2......the new gasket set should come with gromits for the bolts.......i think for both sides it took me like 20 min.....its not hard.....just dont overtorque the bolts....
#4 Gloyale
Gloyale
    It's a sickness
  • 10,560 posts
  • Corvallis, OR PNW
Posted 11 June 2008 - 08:05 PM
If you get you're gaskets from a dealer, you will have to order the grommets seperate.
#5 elmwood22
elmwood22
    USMB Regular
  • PipPipPip
  • 76 posts
  • Deerwood
Posted 11 June 2008 - 09:38 PM
what about cleaning the mating surfaces? Thoughts?
#6 subaru360
subaru360
    has no catchy title
  • 1,282 posts
  • Fleetwood, PA
Posted 11 June 2008 - 10:56 PM
Use brake clean.
