gbhrps Posted December 31, 2003 Share Posted December 31, 2003 Changed the spark plugs on my 02 OBW today and was concerned about finding oil in one of the spark plug holes at 54 000 km. What I mean is that when I pulled the spark plug wire, it was coated with engine oil, as was the spark plug. The inside surface of the spark plug hole through the valve cover had maybe 3 ml of oil in it. I'm guessing that since its only one spark plug, and only a small amount of oil, that I need not be concerned, and yes, I could make it a warranty issue if I wished to. Anyone think I need to be concerned? Quote Link to comment Share on other sites More sharing options...
myles Posted December 31, 2003 Share Posted December 31, 2003 Originally posted by gbhrps Changed the spark plugs on my 02 OBW today and was concerned about finding oil in one of the spark plug holes at 54 000 km. What I mean is that when I pulled the spark plug wire, it was coated with engine oil, as was the spark plug. The inside surface of the spark plug hole through the valve cover had maybe 3 ml of oil in it. I'm guessing that since its only one spark plug, and only a small amount of oil, that I need not be concerned, and yes, I could make it a warranty issue if I wished to. Anyone think I need to be concerned? The seal (not sure if it's an actual rubber seal, or silicone sealant) between the cam cover and the head has been breached. I'd have it fixed. Quote Link to comment Share on other sites More sharing options...
99obw Posted December 31, 2003 Share Posted December 31, 2003 Over time that leak will really make a dirty mess out of the immediate area. I would also have it fixed. Quote Link to comment Share on other sites More sharing options...
pacific_import_auto Posted January 1, 2004 Share Posted January 1, 2004 It's the Spark Plug Tube Seals that leak. Yes, they are rubber, and yes, from my experience, they all leak. For some reason, it seems subaru used a different rubber for those seals than they have used in the past, so they seem to leak more than the older DOHC engines did. I know yours is a SOHC phase 2 engine, but with the spark plugs sitting at the angle that they do, I guess they're more susceptable to oil leaking through than the DOHC engines are with the spark plugs in the side of the head. Just my $0.02 Mike Quote Link to comment Share on other sites More sharing options...
gbhrps Posted January 1, 2004 Author Share Posted January 1, 2004 I appreciate the responses. I'll take it up with my dealership when the car gets its next physical. Many Thanks! A Happy New Year to everyone out there in Subaru Land! Quote Link to comment Share on other sites More sharing options...
