Guest pkdavis300 Posted July 7, 2003 Share Posted July 7, 2003 Well, based on numerous opinions, the main shaft bearing on my 5 speed is shot. Car drives great, just noisy in all gears, so Im off the junkyard for a replacement. It is a 1991 2.2 L AWD 5 speed. Do I need to stay with 1st gen Legacy (1990-199?) or will other year transmissions fit? Also, I hear opinions to remove the motor and trans together and then swap and re-install. Opinions? ...thanks in advance. r/PK Quote Link to comment Share on other sites More sharing options...
Guest Legacy777 Posted July 8, 2003 Share Posted July 8, 2003 you should be able to sway from other years. Just need to make sure the gear ratio is the same for the front and rear. Quote Link to comment Share on other sites More sharing options...
