Been slowly getting an EA82T back together. Last weekend I was putting the passenger (non-distributor) side cam and everything back on. While putting on the 4 bolts for the valve cover I stripped a couple of them. The strange part is, I couldn't even tell I was stripping them till it was to late as the bolts never even got hand tight. So either I don't know my own stregth, or the threads had already been damaged when the previous owner had rebuilt the engine.
So, tore everything apart and helicoil'ed all the valve cover threads, and the threads on the cam retainer (they were stripping too). I then decided to be on the safe side, I went to helicoil the same offending threads on the other side of the engine (distributor side), only to find that some one else had already done it.
I then remembered that the passenger side was the one that always had the "Subaru valve cover leak", but the driver side never had a problem.
Correlation doesn't always imply causation, so I was wondering if anyone else on the board had noticed if helicoil'ed valve cover bolts helped provide a better valve cover seal?
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
helicoil and valve cover leaks
Started by
Beowulfs_Ghost
, Jan 02 2004 05:08 PM
4 replies to this topic
#1
Posted 02 January 2004 - 05:08 PM
#2
Posted 02 January 2004 - 07:51 PM
Ive haven't had a problem yet. I've always acheived torque, none were helicoiled that I know of. I have had other bolts not torque and used helicoils there. I've had around 20/25 of these motors apart.
#3
Posted 02 January 2004 - 08:35 PM
I'm about to helicoil my passenger side as well because of the same problem. Have a few questions and am hoping for a few pointers. --> Is Helicoil better than permacoil? Which size kit do I need and how much can I expect to pay? Did you have any problems drilling out the top right threads? Looks like there is a little less material surrounding it to make room for the cam carrier bolt head. Were you happy with the results? Any help is appreciated.
Thanks,
Thanks,
#4
Posted 02 January 2004 - 10:50 PM
Hey its common for me I have to do it but I havn't had a chance to do it I juse used a longer bolt and a washer and it works but yeah it does still leak a little. Really quick. what size helicoil did you use and what size bit? and where did you get the helicoil?
#5
Posted 03 January 2004 - 01:33 AM
I'm away for the weekend right now, so I can't answer many questions. I haven't done anything since last sunday.
Flow;
One of the bolt holes had to be drilled all the way through, iirc, it was the one closest to the oil spout, so that would be top right.
I'll be able to get the other answers sunday evening.
Flow;
