Subaru_dude Posted July 9, 2008 Share Posted July 9, 2008 Could I drill the symmetrical holes inbetween the a-symmetrical holes of the EA82 flywheel and just have it balanced? I talked to a couple machine shops and they said they wouldn't weld on an iron flywheel (acutally have no idea what my soob's is.. guessing iron). I've also heard of grinding the existing holes with a Dremel to fit the symmetrical pattern. If anybody's done this... what # Dremel bit did you use? Quote Link to comment Share on other sites More sharing options...
Numbchux Posted July 9, 2008 Share Posted July 9, 2008 Could I drill the symmetrical holes inbetween the a-symmetrical holes of the EA82 flywheel and just have it balanced? I talked to a couple machine shops and they said they wouldn't weld on an iron flywheel (acutally have no idea what my soob's is.. guessing iron). I've also heard of grinding the existing holes with a Dremel to fit the symmetrical pattern. If anybody's done this... what # Dremel bit did you use? the holes are not far enough apart to drill a new pattern between them I don't know what number bit, but it was the smaller (~1/4" diameter) grind stone. I think I used up a couple of them.....but I've been running it for almost 35k miles with zero problems. Quote Link to comment Share on other sites More sharing options...
Subaru_dude Posted July 9, 2008 Author Share Posted July 9, 2008 the holes are not far enough apart to drill a new pattern between them I don't know what number bit, but it was the smaller (~1/4" diameter) grind stone. I think I used up a couple of them.....but I've been running it for almost 35k miles with zero problems. Alright good to know!! I will go buy a few of those stones. Thanks!! Quote Link to comment Share on other sites More sharing options...
s'ko Posted July 9, 2008 Share Posted July 9, 2008 I used this. http://power-tools.hardwarestore.com/63-378-hobby-bits-carving/dremel-carbon-cutter-661359.aspx Lasts a long time and cuts great BW Quote Link to comment Share on other sites More sharing options...
Subaru_dude Posted July 13, 2008 Author Share Posted July 13, 2008 That dremel bit worked really well. Quote Link to comment Share on other sites More sharing options...
