OEM or aftermarket?
3 replies to this topic
#1 ettev
ettev
    Subaru Fanatic!
  • 369 posts
  • Pottsville, PA
Posted 15 July 2008 - 12:22 PM
For the EA81 engine gaskets is there any benefit to staying with OEM vs. aftermarket. I know on the EA82's the OEM oil pump gaskets seemed to be better than aftermarket but how about on the EA81's?
In particular I need to replace the front main crank seal, the oil pump gasket and the valve cover gaskets.
OEM or aftermarket?
#2 nipper
nipper
    Semi Elite Master of the
  • 18,179 posts
  • Long Island NY
Posted 15 July 2008 - 02:43 PM
I used name brand aftermarket for mine when i had it.
nipper
#3 grossgary
grossgary
    Elite Master of the Subaru
  • 22,553 posts
  • East Coast
Posted 15 July 2008 - 02:58 PM
you are fine to use after markets on those.
i personally used to use after market with these but since last summer i'm a mostly subaru man.
i had an EA82 Fel-Pro crank seal last year that was very difficult to seat. finally went in but ended up leaking like a seive. replaced it with a subaru seal and all was well so the crank or engine block aren't to blame. i know it wasn't the installation. but i'm not saying that can't happen with subaru gaskets either, im' sure one bad one gets through.
#4 mountaingoatgruff
mountaingoatgruff
    Subaru Nut
  • 622 posts
  • Turlock, Ca
Posted 15 July 2008 - 03:13 PM
i put a fel-pro head set on my ea81. i used their perma-torque head gaskets, valve cover gaskets, valve guide seals, exhaust gaskets and bought fel-pro crank seals. i used a beck arnley oil pump seal kit. the oil pump leaks just a bit but i think its cuz one of the bolt holes was stripped. i also replaced my water pump with a new cardone one, i used the gasket that came with it and a light smearing of water pump/t-stat sealant - no leaks there.
i did go with oem gaskets for the intake manifold, t-stat housing (and oem t-stat) and tb base though. the felpro intake manifold gaskets and t-stat housing gaskets are just lame diecut paper while oem's are not simply paper and they have metal reinforcement in the middle.
i used GD's rvt trick (coat the cork gasket with a thin layer of rtv silicone and allow it to fully cure before installation) on the valve cover gaskets and i was able to reuse them after readjusting my valves with no leaks so far.
