ATTN: whoever it was that was asking about AA100 to AA110 MAF conversion
5 replies to this topic
#1 incognito
incognito
    Banned
  • Banned
  • 441 posts
  • Eagle River
Posted 03 January 2004 - 03:59 PM
I got the wiring diagrams drawn up by hand.. PM me whoever wanted to know how to change the SPFI MAF to the MPFI MAF.
basically goes:
SPFI MAF - unused, R, B, W
MPFI MAF - LgR, R, B, BR, W, unused.
R, B, and W are the same for the ECU... power, ground, signal
Lgr (light green and red) is for the burn-off signal from the burn-off relay.
BR (black and red) is for the (i think) burn off signal ground.
Key points: SPFI doesn't recognise this burnoff mode. MPFI does. The burn-off relay is supposed to activate for 4 seconds after the ignition shuts off only after being in closed loop operation.
Closed Loop, meaning, fully warmed up.
What it does is the hot-wire in the MAF accumulates build up throughout operation. When you turn your car off, for 4 seconds, the burn-off mode is operative. Basically heats the hot-wire up to 1000 degreez or so to burn-off that grime.
Like I said.. Burn-off mode isn't present in SPFI (that i know of).
Take the R, B, and W wires and run em to the correct locations. Ground off (BR) wire to a ground location.
#2 incognito
incognito
    Banned
  • Banned
  • 441 posts
  • Eagle River
Posted 03 January 2004 - 04:11 PM
#3 incognito
incognito
    Banned
  • Banned
  • 441 posts
  • Eagle River
Posted 03 January 2004 - 05:34 PM
bump again.
#4 bushbasher
bushbasher
    exhaust fume addict
  • 1,707 posts
  • Sooke B.C. Canada
Posted 03 January 2004 - 05:41 PM
sweet cause I have an mpfi sensor around, I guess that would be a bit of a flow improvement.
#5 incognito
incognito
    Banned
  • Banned
  • 441 posts
  • Eagle River
thats an understatement...
#6 bushbasher
bushbasher
    exhaust fume addict
  • 1,707 posts
  • Sooke B.C. Canada
Posted 03 January 2004 - 05:48 PM
ya cause the spfi one has a what... 3/4" hole in it? :D
