LanceGillette Posted August 10, 2008 Share Posted August 10, 2008 I've found the main fuse box on the left side of the engine compartment on my 98 Forester. But there must be another fuse box inside the passenger compartment somewhere but I can't see any. Any clues where the other fuse box might be? Quote Link to comment Share on other sites More sharing options...
Cougar Posted August 10, 2008 Share Posted August 10, 2008 Did you look under the dash near the steering column? Quote Link to comment Share on other sites More sharing options...
sea#3 Posted August 10, 2008 Share Posted August 10, 2008 Open coin tray on left side of dash , lift up and remove coin tray from dash and you should see the fuse panel SEA#3 Quote Link to comment Share on other sites More sharing options...
EVOthis Posted August 10, 2008 Share Posted August 10, 2008 +1^ Quote Link to comment Share on other sites More sharing options...
LanceGillette Posted August 10, 2008 Author Share Posted August 10, 2008 I found them exactly where you said they would be. Thanks! I've hunted for them before with no luck. Open coin tray on left side of dash , lift up and remove coin tray from dash and you should see the fuse panel SEA#3 Quote Link to comment Share on other sites More sharing options...
