'92 Loyale 4x4 wagon lift ???
14 replies to this topic
#1 kamikaz
kamikaz
    USMB Regular
  • PipPipPip
  • 47 posts
  • Newark,De.
Posted 07 August 2008 - 06:20 PM
Hey everyone! I'm fairly new to the board & have fallen in love with Soobies! I bought an '87 Justy GL about a year ago & I was hooked! I just bought a '92 Loyale 4x4 wagon & I want to put a 4" lift under it & 14" or 15" wheels. I need help,first of all who carries the lift kits? (I'm gonna have someone else install it).
Next where do you get 14" or 15" four lug wheel? Any & all help or suggestions are well appreciated. I'll be posting pics as the build progresses.
Thanks in advance,
Ray:cool:
#2 The Scooby
The Scooby
    EJ Swap Junkie
  • 1,752 posts
  • South Seattle
Posted 07 August 2008 - 06:49 PM
read a few posts down for lift install ?'s i made.
there are SJR as well as others. i have a 2inch SJR lift and 28's w/ peugeot 15inch wheels.
best friend is to do a search there has been HUNDREDS of posts about the lift kits and such.
also WELCOME TO THE CRAZYNESS THAT IS LIFTED SOOBIES!!
#3 Spiffy
Spiffy
    this road's wide enough
  • 978 posts
  • Portland, OR
Posted 07 August 2008 - 07:11 PM
yeah, sjrlift.com (Scott in Bellingham here on the board) sells lift kits... check them out... there are also directions on this board for making one yourself... but if you're having somebody install it then just buy a kit...
the old peugeot wheels are the only other 4-lug with the same pattern... they're sometimes tricky to find, but they're out there... look on the For Sale forum or post your needs on the Wanted forum... you can also get some chevy, toyota, or nissan 6-lug wheels and drill some extra holes in them to make them fit your hubs... instructions for that are on here somewhere too...
lots of good info in the USRM, and the search feature...
--Spiffy
#4 one eye
one eye
    I'm A Subaholic
  • 2,593 posts
  • Mt.Vernon Washington
Posted 08 August 2008 - 12:03 AM
I would also Look into swaping a D/R trans. in it too. The push button clutch will last for about 10 mins if you go offroad.
Jeff
#5 Phizinza
Phizinza
    Yip yip
  • 3,939 posts
  • South Australia
Posted 08 August 2008 - 12:34 AM
Jeff
If its a manual the push button operates the same mechanisim as a d/r box does for 4wd only without a lever (uses vacuum).
But yes, the dual range gearbox will help a lot offroad and is probably more important then bigger wheels, tires or a lift.
#6 kamikaz
kamikaz
    USMB Regular
  • PipPipPip
  • 47 posts
  • Newark,De.
Posted 08 August 2008 - 02:48 PM
It's a 5 spd. manual trans. Since I am an avid surf fisherman, most of my off-roading will consist of driving on flat sand surfaces. I definetly need the ground clearance & the larger tires to keep the under carriage out of the sand. After I test drive it on the beach, I'll see if I feel it needs the D/R swap. How difficult is the swap? Will it pretty much drop right in or is there a lot involved?
Thanks for all your help,
Ray Hibbs:cool:
#7 one eye
one eye
    I'm A Subaholic
  • 2,593 posts
Posted 09 August 2008 - 01:59 AM
Ray Hibbs:cool:
The linkage is the only thing you'll have to mess with other than that the axles and everything else should fit right in, no problem. you may need the clutch kit and fly wheel from the D/R .
Jeff
#8 kamikaz
kamikaz
    USMB Regular
  • PipPipPip
  • 47 posts
  • Newark,De.
Posted 09 August 2008 - 05:57 AM
Thanks Jeff,
I'm picking up the wagon today! I'll post some pics when I get them.
Ray:cool:
#9 chef_tim
chef_tim
    Romans 5:8
  • 4,780 posts
  • Renner, SD
Posted 09 August 2008 - 08:14 AM
Have I got a deal for you. I have an 87 GL for sale with all the parts you would need to build yours, or just drive as is. The price I'm asking is a lot less then what you're going to pay in parts.
Tim
#10 kamikaz
kamikaz
    USMB Regular
  • PipPipPip
  • 47 posts
  • Newark,De.
Posted 09 August 2008 - 10:41 PM
Tim,
What are you asking for it ? Any pics?
Ray:cool:
#11 chef_tim
chef_tim
    Romans 5:8
  • 4,780 posts
  • Renner, SD
Posted 10 August 2008 - 07:13 AM
Tim,
Ray:cool:
Sorry, thought I put a link to the for sale forum in my post. Here's the pics I have up and the post in the for sale forum is is titled "Blow out Sale"
Car has typical mid west rust but is a great driver. $800 takes it away.
Later, Tim
http://www.ultimates...ery.php?cat=650
#12 kamikaz
kamikaz
    USMB Regular
  • PipPipPip
  • 47 posts
  • Newark,De.
Posted 10 August 2008 - 08:54 AM
If you lived closer, I'd be all over it! :cool:
#13 kamikaz
kamikaz
    USMB Regular
  • PipPipPip
  • 47 posts
  • Newark,De.
Posted 10 August 2008 - 04:45 PM
I'm new at this. What is the difference between an EA81 & EA82? Which D/R tranny would I look for for my '92 Loyale wagon?
Ray:cool:
#14 3eyedwagon
3eyedwagon
    Build it, don't buy it!
  • 708 posts
  • Apache Junction
Posted 10 August 2008 - 04:56 PM
Your 92 Loyale would have an EA82.
The EA81 is completely different engine, used in the early 80s in what is known as the 2nd generation Subaru. These were equipped with a 4 speed dual range transmission. Not all, but alot.
They are the "roundier" more attractive ones. :grin:
That's just my opinion though.
The EA81s are a pushrod engine and the camshaft is timed/driven using gears, whereas the EA82s are overhead cam, and timed/driven using timing belts. There are many other differences, but this is the principle one.
Your Loyale is what would be known as a 3rd generation, or EA82.
Thusly, you would want to find a 5 speed dual range transmission from a 1985-1989 Subaru of some sort.
Good luck!
#15 kamikaz
kamikaz
    USMB Regular
  • PipPipPip
  • 47 posts
  • Newark,De.
Posted 10 August 2008 - 05:36 PM
Thanks for the info! 3eyed.
Ray:cool:
