Headlight fogging cleaning kit
10 replies to this topic
#1 rweddy
rweddy
    1000+ Super USER!
  • 1,408 posts
  • Castle Rock, CO
Posted 10 August 2008 - 11:56 PM
Anyone ever try this kit before?
It is 29.95 and looks pretty good.
#2 edrach
edrach
    RIP 6/28/14
  • 12,326 posts
  • Bothell, WA
Posted 11 August 2008 - 01:49 AM
I used Meguiar's #10 Clear Plastic Polish and only took 5 minutes with a soft, clean rag to get this result:
Posted Image
I don't remember what I paid an 8 fluid ounce bottle of this stuff, but there's enough in the bottle to do 3 or 4 dozen headlamps!
#3 desertsubaru
desertsubaru
    Subaru Nut
  • 806 posts
  • Gassaway WV
Posted 11 August 2008 - 06:24 AM
The body shops use a fine rubbing compound and a rotary
buffer and it does just as well.
#4 axel
axel
    User Awaiting Email Confirmation
  • PipPipPip
  • 43 posts
  • Northern California
Posted 11 August 2008 - 06:58 AM
In past years, we had glass headlights.:clap: Worked just fine, Cost just a small fraction of the current plastic ones to replace. No problem with them going opaque or yellowing like the plastic ones. European style, non sealed beam headlights had replaceable high intensity bulbs for great illumination. Came in just a few sizes (round or rectangular)unlike the current plastic ones that are made in hundreds of cinfigurations to fit individual make and model cars, which make them incredibly expensive.:eek:
Why this trend to form over function? What went wrong??? :confused: Just like the stupid trend to color coordinated, very easily damaged, and very costly to repair/replace bumpers ....don't get me started on that one!:rolleyes: Of course, Subaru followed the herd. O.K. rant over for now.:)
#5 axel
axel
  • PipPipPip
  • 43 posts
Posted 11 August 2008 - 07:08 AM
I used Meguiar's #10 Clear Plastic Polish and only took 5 minutes with a soft, clean rag .
Yeah, Meguiar's is pretty good, as long as you don't let the headlights get too hazy/oxidized before using it.
The secret to keeping your plastic headlights clear is to clean/polish them regularly.....like about every 10 days.
#6 rweddy
rweddy
    1000+ Super USER!
  • 1,408 posts
  • Castle Rock, CO
Posted 11 August 2008 - 08:09 AM
Great, thanks for the input.
I think I will try a hybrid approach & do the 800/1500 wet sanding then use the Meguiar's and some type of buffing wheel.[FONT="][/FONT]
#7 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 6,712 posts
  • Virginia
Posted 11 August 2008 - 08:21 AM
i just picked up a kit from advance auto. basically the same with 2 differences, no polishing tool and therefore no directions for using a drill, and the polishing compound and sealer come in foil pouches, one use.
it was 19.99. seemed high for sand paper and stuff, but i had no idea hw to do it so that's worth somthing. they stress correct application of the sealer, 2 coats.
#8 edrach
edrach
    RIP 6/28/14
  • 12,326 posts
  • Bothell, WA
Posted 11 August 2008 - 08:25 AM
Ditto to that. Applying a coat of wax after polishing will extend the time to 20+ days.
#9 axel
axel
  • PipPipPip
  • 43 posts
Posted 11 August 2008 - 10:14 AM
Another problem with plastic headlights is that they become pitted over time from gravel and road debris impact.
I've used plastic headlight protectors( the ones that I installed were made by 3M).
They're made of a clear,soft, flexible material with adhesive.
After about 6 years, I had to remove one of them due to it becoming heavily discolored, apparently from constant direct sunlight exposure; Couldn't remove the discoloration so I removed the protector. Pulled off pretty easily after first heating it with a hair dryer. But the adhesive remained on the headlight surface. It was a nightmare to clean off. Denatured alcohol didn't work. Was afraid to use a stronger solvent for fear of damaging the headlight surface. I used "Goop" cleaner and LOTS and LOTS of rubbing. Took quite a while. But those protectors do, indeed, work quite well.
#10 edrach
edrach
    RIP 6/28/14
  • 12,326 posts
  • Bothell, WA
Posted 11 August 2008 - 10:22 AM
A good solvent to use to remove adhesives is WD-40. Not sure if it works on the adhesive used for the headlamp protector, but works great on adhevise left behind from bumper stickers and similar plastics.
Use the WD-40 to dissolve and remove the glue and then brake cleaner or something similar to remove the WD-40.
#11 aa8jzdial
aa8jzdial
    USMB Regular
  • PipPipPip
  • 114 posts
  • muskegon michigan
Posted 11 August 2008 - 06:59 PM
Foggy lenses are a big pain and expensive to replace.
A quick and easy fix that will bring out the shine is a rub of the lenses with a rag barely wet with brake fluid.
Be quick and careful as it will soften the polycarbonate (that the right name of the material?).
It won't make them brand new but 2 minutes every so often helps a lot.
gl
