Noisy transfer case?
6 replies to this topic
#1 williamhilow
williamhilow
    USMB Regular
  • PipPipPip
  • 56 posts
  • Oakland, CA
Posted 06 January 2004 - 03:17 PM
Hey dudes!
Got a noisy little 91 Loyale. Runs strong, 120k great mileage etc....
auto tranny makes a real high pitched whining sound. Pretty sure that its not the tranny but the transfer case. Oil is fresh in the transfer case and rear dif. Bad transfer case right? Well then why does the noise go away when I engage 4wd? I mean it goes away completely, like no noise at all. Is there a zirk fitting I need to hit with some grease?
Thanks,
Bill Hilow Member since 1991!
williamhilow@yahoo.com
#2 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 06 January 2004 - 03:29 PM
Bill,
I'm goin to move this to the old gen side since the loyale was more of an old gen style car.
#3 Guest_taprackready_*
  • Guests
Posted 06 January 2004 - 03:36 PM
Sub's don't have a seperate transfer case like traditional 4x4's. Transaxle has an intergrated transfer case if you can call it that, and if your oil is good in the tranny then all the gears are getting lubed.
Another possiblity is the U-Joint is going out and making a noise.
Bill
#4 samo
samo
    Boo.
  • 731 posts
  • The Emerald City
Posted 06 January 2004 - 05:10 PM
I've kinda wondered about this too. My tranny has always been whiny, although it's not super-loud or anything, just a high-pitched whine that goes up with RPMs. Mine is just as whiny in 4WD, though. Seems to run and shift just fine, though.
#5 tcspeer
tcspeer
    1000+ Super USER!
  • 1,444 posts
  • Walnut Springs
Posted 06 January 2004 - 08:33 PM
Has the transmission filter been changed? If the filter gets stopped up it can cause the transmission to whine.
#6 bushbasher
bushbasher
    exhaust fume addict
  • 1,707 posts
  • Sooke B.C. Canada
Posted 06 January 2004 - 08:44 PM
a whine can be caused by a misaligned ring and pinion. The 4wd could be taking the load off the front diff, causing the noise to stop.
#7 Ozsubie
Ozsubie
    New User
  • PipPip
  • 26 posts
  • Adelaide
Posted 06 January 2004 - 09:49 PM
I had a very strange one with my Auto EA82 in that if you screwed the speedo cable down tight onto the attachment at the gearbox you'd get quite a noticeable whine at certain speeds. The noise would disappear by selecting 4WD. :confused: Leaving the speedo cable attachment slightly loose at the gearbox would get rid of the noise in 2WD mode.
