Guest wthramann Posted July 4, 2003 Share Posted July 4, 2003 Well Summer has finally arrived. I was driving my wife's '96 Legacy Wagon today and thought the air conditioner output felt only cool not cold. Does anyone have a performance chart for the Subaru A/C? You know one of those graphs where if you know the ambient temperature/humidity you can determine what the delivery temperature should be. I might be spoiled by my '88 Accord's R12 output which is in the 30's. Quote Link to comment Share on other sites More sharing options...
Guest Legacy777 Posted July 4, 2003 Share Posted July 4, 2003 r134a cools just as well as r12. I did a conversion on my old r12 system and it converts just as well if not better. You are most likely low on refrigerant/oil. Quote Link to comment Share on other sites More sharing options...
Guest wthramann Posted July 5, 2003 Share Posted July 5, 2003 So I should use an R12 performance table? Quote Link to comment Share on other sites More sharing options...
Guest scoobtech Posted July 5, 2003 Share Posted July 5, 2003 No , R134a runs at a higher pressure . An R12 chart will be incorrect info . :x Quote Link to comment Share on other sites More sharing options...
Guest hocrest Posted July 5, 2003 Share Posted July 5, 2003 I just recharged the system in my 97 Legacy. When I got the refill kit I also got one of the pressure checkers. I filled it up to just under 44 which is where they recomend to stop. I've left a kitchen thermometer in my vent and and I haven't seen it go below about 43 degrees. Sitting at idle it hovers between 55-60 degrees. For the last week since I did the refill it has been in the 85-95 degree range with moderate humidity. Is this right? Any possibilities to get it colder. Quote Link to comment Share on other sites More sharing options...
Guest 1 Lucky Texan Posted July 5, 2003 Share Posted July 5, 2003 If it noticeably gets warmer at a stop, you may have one or more radiator fans not working. The A/C condenser (whatever) doesn't have any air going through it unless you're moving forward. Could bvesomething else though - just an observation from other vehicles I've had.. Carl 1 Lucky Texan Quote Link to comment Share on other sites More sharing options...
Guest wthramann Posted July 5, 2003 Share Posted July 5, 2003 The Honda R12 performance chart shows at an intake temperature 90 degrees, humidity 60%, delivery temperature of 59 degrees at 1500rpm, fresh air, front doors open, in the shade, max fan, no one in the car. So maybe you are getting acceptable performance. Quote Link to comment Share on other sites More sharing options...
