Occaisonal Heat Issues, beach driving, EA81
1 reply to this topic
#1 Mikldom
Mikldom
    USMB is life!
  • 174 posts
  • E.C NC and Tidewater, VA
Posted 20 August 2008 - 09:44 AM
Ok.. BRAND new copper/brass (not plastic or aluminum) radiator installed..
fully working thermo, water pump only 1 year old, block flushed.
driving around, no problem.. at idle, or sllloooww speeds at high rpm (low range for driving on beach), the guage will go all the way to 3/4, but not touch the red, fans come on, and it slowly goes down.. I have the original fan and the ac fan wired together to both come on.. but heat under these conditions are worrisome..
Should I just get one of the aftermarket performance fans? for better airflow? or what about this misting additional cooling system...looks promising.. http://www.partsamer...tegoryCode=6003
everything on the cooling system is in top notch, and with brand new good radiator, we can throw this out.
could it be my low voltage condition causing a problem (but not at high idle)..
Thanks!!
#2 nipper
nipper
    Semi Elite Master of the
  • 18,179 posts
  • Long Island NY
Posted 20 August 2008 - 11:12 AM
Can be tired fans.
nipper
