bigo1966 Posted September 3, 2008 Share Posted September 3, 2008 For the new to me Sedan, i want to run 27" tires. Should i go with a 4" lift or 2" suspension lift and some fender trimming? Anything i should know about lifting the sedan 4"? Quote Link to comment Share on other sites More sharing options...
bratman18 Posted September 3, 2008 Share Posted September 3, 2008 For the new to me Sedan, i want to run 27" tires. Should i go with a 4" lift or 2" suspension lift and some fender trimming? Anything i should know about lifting the sedan 4"? What kind of lifts options are you considering?? Quote Link to comment Share on other sites More sharing options...
bigo1966 Posted September 3, 2008 Author Share Posted September 3, 2008 A used 4" AA lift and a home brew 2" lift. Quote Link to comment Share on other sites More sharing options...
bratman18 Posted September 3, 2008 Share Posted September 3, 2008 A used 4" AA lift and a home brew 2" lift. If your looking to fit 27s then I would go with the 4" but if you got a good idea for you 2" and it will work well then go for it!! What would you do for the homeade lift? Quote Link to comment Share on other sites More sharing options...
bigo1966 Posted September 3, 2008 Author Share Posted September 3, 2008 2" strut top lift in front and drop the X member a little. Then space the rear coils 2", or find longer ones that provide more travel like the air struts i ran on the the rear of the buggy. Quote Link to comment Share on other sites More sharing options...
bratman18 Posted September 3, 2008 Share Posted September 3, 2008 2" strut top lift in front and drop the X member a little. Then space the rear coils 2", or find longer ones that provide more travel like the air struts i ran on the the rear of the buggy. I did a 3'' home built on my brat but is based on one from sjr but with a few differences. I used adjustable front struts and then spaced everything down but didn't drop the rear pumpkin as much but its a little different with the ea82 body style so good question? Which will give you more clearance and let you fit the big tires at the same time?!?!? That's what I would go with:headbang: Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 3, 2008 Share Posted September 3, 2008 For the new to me Sedan, i want to run 27" tires. Should i go with a 4" lift or 2" suspension lift and some fender trimming? Anything i should know about lifting the sedan 4"? what tires? if they are not to wide just a little trimming on a 2" Quote Link to comment Share on other sites More sharing options...
bigo1966 Posted September 3, 2008 Author Share Posted September 3, 2008 The tires will be 27x9's. And chances are they will stick out a little due to the wheels im going to run. Quote Link to comment Share on other sites More sharing options...
