Any Docs in the House? Want to Diagnose?
7 replies to this topic
#1 nwsunni
nwsunni
    New User
  • PipPip
  • 14 posts
Posted 04 September 2008 - 08:48 PM
Hi ==
Anybody want to take a stab at what this brand new problem might be?
Auto: 89 Subaru Gl Sedan Manual 170,000 Miles and yes, it leaks oil.
At idle, no unusual sounds. Seems fine.
At idle, when I give it gas or back off the gas, I hear a rumble coming from the engine. It seems to be on the driver's side.
When I hold the gas at a set speed, I don't hear the rumble. It's loud. It just started an hour ago. .
Any suggestions on how I can better describe the noise?
Thought it kinda sounded like exhaust but just had new muffler put on about a month ago.
#2 cobcob
cobcob
    User Awaiting Email Confirmation
  • 710 posts
Posted 04 September 2008 - 08:54 PM
If you're suspecting exhaust then take a look at the Exhaust Manifold gaskets, and donut gasket...
Doesn't sound like that from your description but it could be.
#3 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,617 posts
  • Portland
Posted 04 September 2008 - 08:55 PM
Sounds like a blown-out exhaust gasket to me. Having the muffler done wouldn't make any difference - in fact having it done so recently might have *caused* the blow-out due to jostling of the exhaust when they installed it and additional back-pressure from replaceing the old one that I assume had holes or other serious issues. They also may not have used the correct gaskets on the muffler-to-midpipe flange. If you don't use gaskets that have the metal sealing ring on the ID they will blow out quickly.
#4 nwsunni
nwsunni
    New User
  • PipPip
  • 14 posts
Posted 04 September 2008 - 10:15 PM
Thanks folks..for the speedy replies. Your replies prompted me to get under the car. Ick. Ouch. I can see a pipe up front that has a seam on it that has split. As you can tell, I'm no car expert. It looks like it's part of the exhaust system.
If it's not one thing, it's...
#5 Indrid cold
Indrid cold
    Subaru Nut
  • 788 posts
  • Kennewick, WA
Posted 05 September 2008 - 03:28 AM
possibly ask local member to stop by and have a peek?
The more you know the less chance getting taken $.
#6 Loyale 2.7 Turbo
Loyale 2.7 Turbo
    The Mighty "BumbleBeast"
  • 7,528 posts
  • Roatán, Honduras.
Posted 05 September 2008 - 07:28 PM
... I can see a pipe up front that has a seam on it that has split...
...it is the Exhaust Pipe...
Did you say "Rumble" Sound? ... Could it be a Worn Ball Bearing from one of the Timin` Belt`s Tensioneers?
I Suggest to Start the Engine and go hear it close, accelerate it Manualy, Slowly untill the Noise Come and Go, and Try to Determine the place where it Comes From...
Good Luck! :burnout:
#7 Sonicfrog
Sonicfrog
    Certified Subaru Nut
  • 834 posts
  • Fresno
Posted 17 September 2008 - 12:43 AM
Yeah, it sounds like exhaust to me.
This spring I pulled an engine to fix... something - i don't remember, it becomes a blur after a while, - and three weeks after I put the engine back in, I started to hear a similar noise. I was sure I split the front pipe. When I finally got under and took a looksee, I found that some knucklehead (me) forgot to put the exhaust bolts on the passenger side exhaust manifold.... :horse:
#8 torxxx
torxxx
    I void warranties
  • 2,918 posts
  • Fairbanks
Posted 17 September 2008 - 05:41 PM
Hi ==
If it doesnt leak oil, its not a subaru...
