Coolant Smell From Heater
9 replies to this topic
#1 Atomic Robot
Atomic Robot
    USMB is life!
  • 182 posts
  • Solon
Posted 08 January 2004 - 11:48 PM
It's been really cold around here lately, and over the past couple of days I've started to notice what I believe is the smell of coolant coming from the heating vents.
Up until now I've really only been using the windshield setting to clear off fog, but yesterday I had the heater cranked and noticed the smell.
Smelled it again on my way home from work today. Checked under the hood and didn't see anything out of the ordinary; coolant level in the overflow was the same as when I looked at it a week ago / no bubbles or strange smells coming from the tank / didn't see any obvious leakage on the engine.
What's going on?
#2 Guest_lothar34_*
Guest_lothar34_*
  • Guests
Posted 09 January 2004 - 02:02 AM
Are there any damp spots on the floor under the dash by the console?
#3 intrigueing
intrigueing
    USMB Regular
  • PipPipPip
  • 115 posts
  • IL
Posted 09 January 2004 - 08:33 AM
Loose hoses, or heater core? I dread even saying the worst possibility, that headgaskets are heading south, however your symptoms are not the "tell tale ones".
#4 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 09 January 2004 - 09:17 AM
I'd first see if you notice any leaks around the heater core itself.
#5 tcspeer
tcspeer
    1000+ Super USER!
  • 1,444 posts
  • Walnut Springs
Posted 09 January 2004 - 09:36 PM
Any leak under the hood can smell like it is in the car. My 97 Legacy 2.2 is doing the same thing right now, and I also have not seen the water level go down in water tank resovoir. I am thinking water pump on mine, but hoping it is not head gasket. Just a small drop of coolant getting on some part of warm engine will really smell.
#6 Atomic Robot
Atomic Robot
    USMB is life!
  • 182 posts
  • Solon
Posted 16 January 2004 - 10:42 AM
Well, I don't know what's up at this point...
Got a coupon for a cheap oil change at the dealer and didn't feel like doing it myself in this weather, so I also had them pressure test the cooling system.
According to the mechanic, there were no leaks. The service manager mentioned that they checked bolts for proper tightness, etc. so I guess nothing major is wrong. I don't think they drove it long enough for the coolant smell to appear, though.
#7 amphibo
amphibo
    New User
  • Pip
  • 6 posts
  • Hagerstown, Maryland
Posted 22 January 2004 - 07:04 AM
We have a 2001 Legacy sedan with 61,000 miles on it and last Friday my wife came home complaining about a strong 'engine smell' while driving around town.
I went out and checked the coolant level... way down. Uh oh, started up the car, looked underneath and saw the telltale bright green color of the coolant dripping out from behind the oil pan.
Ironically, I'd just made an appt with the dealer for the 60K service. When I took it in they confirmed it was a blown head gasket. I was very surpised when they offered to have it fixed under the power train warranty. Like a bad cartoon, I was sure that being 1200 miles over I was going to have to argue my way to a compromise.
I'm sure they're making plenty off of all the other work but happy to not add the head gasket to the final tally.
With this engine it seems like one time an extended warrenty is worth the extra $$.
Good luck.
#8 Alan Phillips
Alan Phillips
    New User
  • Pip
  • 6 posts
  • Crestline, CA
Posted 22 January 2004 - 11:29 PM
It is strange, but it will leak when cold! My 2000 Outback only leaks when it is warming up from the head gasket on the pasenger side towards the fire wall. Once warmed up it seals back up. I have noticed the colder the worse(20's 30's here in the Cali mountains.
You smell it really strong because it leaks directly on the exhaust or exhaust shield. This explains why you do not see any leak on the ground. If you can jack up the car and look at the back you should see residue or take it to a mechanic and have it cool down. Put it on a rack and start it up and you'll spot it. The reason that it checked out ok is because the engine was warm. Try it cold! I got 20 thats the prob. Looks like Sub dealership mech. will be busy.
#9 Tiny Clark
Tiny Clark
    Certified Subaru Nut
  • 807 posts
  • Germany
Posted 23 January 2004 - 07:01 AM
USUALLY, if there is a leak in the heater core, and you are using the defroster, it will put an oily film on the windshield.
#10 Atomic Robot
Atomic Robot
    USMB is life!
  • 182 posts
  • Solon
Posted 23 January 2004 - 12:14 PM
This may be what's going on with mine, as well. Never noticed it at all until it got really cold here, and have never seen any leaks. Definitely a stronger smell outside and no goo on the windshield so I don't think its the heater core.
Just spotted the Head Gasket Warranty thread and will definitely be following up with the dealer on it.
