outbackusjunkus Posted December 3, 2008 Share Posted December 3, 2008 '97 outback...wipers were frozen to the windshield...when I broke the driver's side loose it started working (forgot the switch was still on) but passenger side is now loose and does not work at all. did I break it...if I leave it sit will it heal itself? (didn't work for the headgaskets)... Quote Link to comment Share on other sites More sharing options...
bratman18 Posted December 3, 2008 Share Posted December 3, 2008 I think maybe the linkage broke. You would have to pull off the plastic trim on front of the windshield, the piece that the wipers go down through. Then you can see whats wrong. Or it could just be that they nut that holds the wiper down actually loosened up a little. Check that first. Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted December 3, 2008 Share Posted December 3, 2008 i bet the linkage is fine, i bet the "grooves" of the wiper arm where it attaches are stripped. easy fix. to fix. take off arm retainer nut to the side not working. check the grooved/probably find pieces of metal. get a small piece of screen wire, the metal kind. enough to fit over the wiper stud. place arm back on, tighten nut. the screen wire will cause it to grip again. rock on Quote Link to comment Share on other sites More sharing options...
bratman18 Posted December 3, 2008 Share Posted December 3, 2008 i bet the linkage is fine, i bet the "grooves" of the wiper arm where it attaches are stripped. Easy fix. To fix.Take off arm retainer nut to the side not working. Check the grooved/probably find pieces of metal. Get a small piece of screen wire, the metal kind. Enough to fit over the wiper stud. Place arm back on, tighten nut. The screen wire will cause it to grip again. Rock on +1 Quote Link to comment Share on other sites More sharing options...
nipper Posted December 3, 2008 Share Posted December 3, 2008 The brooves in the wiper arm are softer then the linakge, and made to give way when somone makes this er um .... "miscalculation" Remove the wiper arm cap and i bet you will see the nut turning. nipper Quote Link to comment Share on other sites More sharing options...
outbackusjunkus Posted December 4, 2008 Author Share Posted December 4, 2008 Awesome...I knew there would be an easy fix...thanks! Quote Link to comment Share on other sites More sharing options...
bratman18 Posted December 4, 2008 Share Posted December 4, 2008 Awesome...I knew there would be an easy fix...thanks! Let us know what you find! Quote Link to comment Share on other sites More sharing options...
