smells like unleaded
Yep. Fuel and brake lines run under the trim on the door sill, then up the firewall. Less chance of damage to them that way.
Would also check the vapor canister under the hood. They have been known to give off fumes at times. Did you cap-off the float bowl vent line going to tyhe vapor canister, when you did the Weber swap? You should have.
