water pump question
19 replies to this topic
#1 subegrl
subegrl
    USMB Regular
  • PipPipPip
  • 102 posts
  • alabama
Posted 11 January 2004 - 09:16 AM
when I get my timing belt changed in my 01 forester, should I get the water pump changed too?
I assumed that I did, but someone told me that not all cars are like this, some have easier access to the water pump so changing out one just because you have things taken apart to get to the timing belt isn't necessary.
#2 theotherskip
theotherskip
    Eat, Live, Breath Subaru
  • 329 posts
  • Philly, PA
Posted 11 January 2004 - 09:25 AM
on subaru engines, the water pump is driven by the timing belt, so if it ever fails, you have to remove the timing belt to replace it. everybody has different opinions on if you should change the pump or not, mostly depending on mileage and how long you plan to keep the car. when i did my timing belt and head gaskets at 72k, i replaced the pump, since i was changing everything else. it was only around $60 from www.1stsubaruparts.com, and i can't imagine installation would be that much more.
#3 lmdew
lmdew
    _______
  • 3,408 posts
  • Colorado Springs
Posted 11 January 2004 - 09:37 AM
I change mine every other timingbelt change. Of course I check it carefully along with all the other parts at every change.
#4 1 Lucky Texan
1 Lucky Texan
    I read a lot about Subarus
  • 6,243 posts
  • Texas
Posted 11 January 2004 - 09:49 AM
It MAY depend on your personal tolerance for risk combined with your personal mechanical skills. Also, I think if the belt breaks on an '01 Forester, you're gonna have bent valves. If, say , you will pay a mech. to do do the work on a daughter's car that will drive 200 miles every other weekend to and from college - I say you spring to replace everything that touches the belt. If you are adept at doing the work yourself on you personal daily driver that is never more than 20 minutes from your home - just change the belt - IF a tensioner bearing seizes and melts through the belt (this happened to me on a Toyota, 3K after the first scheduled belt change and 200 miles from home with my daughter in the car) you can get it home and fix it yourself.
Because of an 'anecdotal' experience I had, I will always change evrything(within reason) in there.
#5 99obw
99obw
    this space for rent
  • 1,595 posts
  • Ithaca area
Posted 11 January 2004 - 12:05 PM
To me it depends on the timing belt interval for your car. If it is 105k like our outback, I would change the water pump. If the interval was say 60k on the timing belt, I would change the pump at 120k.
Like Carl said, idlers do tend to "dry out". I would also consider; thermostat and gasket, cam seals, main seal, oil pump o-ring, loctite back cover and reseal oil pump, accessory belts, dipstick tube o-ring, maybe valve cover gaskets, oil filler o-ring, and bolt seals.
#6 subegrl
subegrl
    USMB Regular
  • PipPipPip
  • 102 posts
  • alabama
Posted 11 January 2004 - 01:32 PM
...a list of what you'd replace is most welcome!
The interval for the Forester is also around 105k. I drive it long distances every weekend to go paddling, so I want it to be as 'bomber' as possible. Also I intend to drive it as long as I can, right now it has 93k miles but I'm about to get surgery on my arm, which means I won't be able to drive it for a few weeks (stick shift) so now is a good time to get things done to it.
Any other suggestions of what you'd get replaced?
Thanks
#7 1 Lucky Texan
1 Lucky Texan
  • 6,243 posts
  • Texas
Posted 11 January 2004 - 06:56 PM
I wouldn't use aftermarket belt - OEM only.
#8 richierich
richierich
    Moderator
  • Moderator
  • 3,760 posts
  • Portland
Posted 16 January 2004 - 03:48 AM
I would also get the front crank seal replaced. Very unlikely it will last out to 210k miles. Should be relatively inexpensive.
Richierich
SIR, Inc
#9 meep
meep
    USMB Regular
  • PipPipPip
  • 79 posts
  • No. AL
Posted 16 January 2004 - 02:12 PM
does the 01 use chain driven cams??
My H2O pump died at 105,000. Not quite long enough to make 2nd T-belt change. I've heard that's just about right for soobe pumps. Bosch replacement cost $50.
DITTO THE OEM T-BELT ONLY!!!!!!!!!!!
mike
#10 cookie
cookie
    Elite Master of the Subaru
  • 3,058 posts
  • SFO
Posted 16 January 2004 - 05:01 PM
everthing thses folks on this board told me about needed to be done to my Forester at the first belt change interval.
There was slight leakage of oil so it got crank seal and oil pump done.
The water pump had a bit of play but I was going to have it changed regardless after hearing of it taking out timing belts and valves.
Of course I had the usual leaking head gaskets and the second rate clutch. If you are going to do the clutch you might as well change the plastic oil slinger on the back of the engine for metal.
I would change the oil seals and the water pump on your car for sure with the belt.
#11 subegrl
subegrl
    USMB Regular
  • PipPipPip
  • 102 posts
  • alabama
Posted 17 January 2004 - 05:42 PM
what is a good test for the external leak? I haven't had any problems, but I have been reading the posts on here about head gaskets and apparently *if* I had a leak it would be external - so what is a good test for it?
Oil seals - where do these go and what do they do?
Does the 'overhaul gasket set' include these seals = a better question might be what *is* included in the Overhaul Gasket Set? (listed on 1stSubaruparts.com).
So far I am set to replace: timing belt, water pump, radiator hoses, thermostat, radiator cap, spark plugs, fuel filter.
Differential - how do you check the fluid in a manual transmission? Should I have this drained and filled with new stuff?
Clutch is the Tax Return project -
#12 torxxx
torxxx
    I void warranties
  • 2,918 posts
  • Fairbanks
Posted 17 January 2004 - 05:54 PM
there's a dipstick on the tranny fowards the firewall... May have to really look around to find it on the new soobs.
You could change the gear oil, but look at it and see how the oil condition is.
I usually change my tranny oil once a year. to do that, its about straight down from the stickshift on the bottom of the tranny theres a 21 or 22 mm drain plug. Drain and put plug back in, then fill through the tranny dipstick.. Slowly squirt the gear oil in, if you put too much in, it will burp out gear oil all over everything
Oil seals go on the front of the crankshaft, back of the tranny, sides of the tranny where the axles stubs stick out, in the rear end, and on the oil pump
#13 theotherskip
theotherskip
  • 329 posts
  • Philly, PA
Posted 17 January 2004 - 09:45 PM
oil seals seal any time something rotating has to exit the block - where the cams leave the head, etc.
if you are having the work done, the mechanic will probably order the specific parts you need. the overhaul gasket set has more parts than you would need for what you are probably going to get done. but here is the list of what is included.
Posted Image
when you get all of the parts, none are labeled, and it is kind of a guessing game as to what is for what. i had some left over when i was done... and it doesn't include the valve cover gaskets or spark plug hole gaskets (though it includes the valve cover bolt seals, go figure...)
i wrote a site about changing the head gasket and changing the clutch. it may give you a better idea of the work involved, though a mechanic would probably not pull the engine... you can view it here . i don't think i would have it done unless it is giving you warning signs...
#14 99obw
99obw
    this space for rent
  • 1,595 posts
  • Ithaca area
Posted 18 January 2004 - 06:42 AM
Skip, she has a Phase II, does that list still apply?
The Phase II doesn't have spark plug hole gaskets AFAIK.
#15 theotherskip
theotherskip
  • 329 posts
  • Philly, PA
Posted 18 January 2004 - 09:31 AM
i forgot she has a phase 2. i assume it is the same. maybe that is why they don't include certain gaskets that are not common to both engines...
#16 subegrl
subegrl
    USMB Regular
  • PipPipPip
  • 102 posts
  • alabama
Posted 18 January 2004 - 09:39 AM
OK on 1stsubaruparts I see a listing for: oil seal, cover seal, rear main seal, front crank seal, valve seals. Would you replace all of these?
#17 99obw
99obw
    this space for rent
  • 1,595 posts
  • Ithaca area
Posted 18 January 2004 - 10:37 AM
I would replace the parts I listed above. When I said main seal I meant front main seal specifically. The rear main seal should be replaced when you do the clutch.
#18 torxxx
torxxx
    I void warranties
  • 2,918 posts
  • Fairbanks
Posted 18 January 2004 - 06:08 PM
I dont think its time to worry about all the oil seals just yet.
if anything the front and back crankshaft seals
and tranny seals should be all that car needs if it needs any of it done
#19 99obw
99obw
    this space for rent
  • 1,595 posts
  • Ithaca area
Posted 18 January 2004 - 09:41 PM
Replacing the rear main seal requires the removal of the engine or transmission, so doing that when the clutch is done makes the most sense.
When this belt is done that area of the engine shouldn't need attention until 210k. I personally wouldn't trust any seals for that long if I had the opportunity to replace them relatively inexpensively while in the area.
#20 NOMAD327
NOMAD327
  • 343 posts
  • danville, PA
Posted 19 January 2004 - 08:05 AM
The front seal or oil pump o-ring on my 99 Outback with 65,000 miles is already dripping quite a bit. If I had one with 105,000 that wasn't leaking, I wouldn't expect it to go another 105,000 miles without problems
