EA82 Crank Pulley removal help
10 replies to this topic
#1 cmiller
cmiller
    Flat 4
  • 735 posts
  • Tigard, OR
Posted 13 December 2008 - 09:43 PM
I've been trying to take off the crank pulley on my '92 Loyale so I can replace the timing belts. I took off the starter and had a pry bar stuck on the flywheel teeth to keep the crank from turning. Also using a t-handle with the 22mm socket on the crank pulley nut. Is the nut that holds on the pulley reverse thread instead of righty tighty? :confused: I can;t get the dang thing to budge! :banghead::Flame:Any suggestions?? Tips?? I need that pulley off so I can get the last timing belt cover off to put on the belts.
I wanted to get these timing belts on so I can play in the snow this weekend!!!
#2 subiemech85
subiemech85
    SIX STAR SERVICE
  • 2,710 posts
  • down by the river
Posted 13 December 2008 - 10:19 PM
it is a standard bolt
someone may have applied loctite, which may require :Flame: to remove
you should use 3/4" wratchet with LONG pipe
OR use zzz to remove cover
naked belts are beautiful
#3 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,615 posts
  • Portland
Posted 13 December 2008 - 10:20 PM
Pull the #1 plug and with the piston at BDC thread about 10 feet of 1/4" nylon rope into the cylinder. Use a 1/2" breaker bar and socket to remove the bolt - they are not left-hand thread - turn it out just like any other bolt.
#4 DaveT
DaveT
    Subaru Nut
  • 3,605 posts
  • Colchester
Posted 13 December 2008 - 10:28 PM
My solution has been to put a box end wrench on one of the 4 bolts that holds the tourque converter to the sheet metal that connects to the crankshaft. The wrench stops the rotation when it touches the side of the timing view port. But that probably only works on an AT....
#5 GeneralDisorder
GeneralDisorder
  • 21,615 posts
  • Portland
Posted 13 December 2008 - 10:30 PM
Yes - it only works on AT's.
#6 brokebill
brokebill
    USMB is life!
  • 195 posts
  • gatlinburg
Posted 13 December 2008 - 10:41 PM
i love that easy access.
been off a year and belts/pulleys aint even dirty.
good luck, Bill
#7 Loyale 2.7 Turbo
Loyale 2.7 Turbo
    The Mighty "BumbleBeast"
  • 7,528 posts
  • Roatán, Honduras.
Posted 13 December 2008 - 10:46 PM
I Suggest to Spray some good Penetrating oil, then give Small hits to the Nut, so it makes it Easy to Turn.
Be Careful when Pulling the Pulley, a stuck Pulley must be pulled Carefully because if you use a Tool between the Pulley and the Engine Block, the Pulley can Break!
Good Luck!
#8 mudduck
mudduck
    Subaru Nut
  • 708 posts
  • Asheboro NC
Posted 14 December 2008 - 12:11 AM
Put a breaker bar on the pully bolt thats long enough that the end sits on the subframe rail and bump the engine.
#9 Indrid cold
Indrid cold
    Subaru Nut
  • 788 posts
  • Kennewick, WA
Posted 14 December 2008 - 03:21 AM
put a breaker bar on the pully bolt thats long enough that the end sits on the subframe rail and bump the engine.
+1
#10 cmiller
cmiller
    Flat 4
  • 735 posts
  • Tigard, OR
Posted 14 December 2008 - 12:00 PM
I only have metric sets since this is a Japanese car. But the 22mm fits like a glove on there. Thanks for the LONG pipe idea, I actually used an old broom handle.:)
It finally moved! More leverage was what it needed. Thanks all for the tips. Now I can get this thing done and just in time, There is all ready 3" of snow on the ground when I woke up this morning!:banana:
Edited by cmiller, 14 December 2008 - 12:04 PM.
#11 Andy FitzGibbon
Andy FitzGibbon
    Eat, Live, Breath Subaru
  • 335 posts
  • Elkins, WV
Posted 14 December 2008 - 01:43 PM
I think he meant a 3/4" DRIVE, not a 3/4" socket.
Andy
