No Tail / side marker lights help!!!!!
10 replies to this topic
#1 WickedV6
WickedV6
    USMB Regular
  • PipPipPip
  • 31 posts
  • ELBURN, IL
Posted 16 December 2008 - 03:51 PM
I have signal and brake lights however no tail lights or front side marker lights. I checked the fuse labled "tail" in the kick panel on the drivers side. It looks good. Am I missing something? Am I looking at the right fuse? This is a 1995 Legacy.
T.I.A
Prasad
#2 bratman18
bratman18
    ADIDASubarus
  • 3,846 posts
  • Jefferson, Maine
Posted 16 December 2008 - 03:59 PM
Check all fuses! Not just one. I had this happen to me when I installed an aftermarket radio. It shorted and blew the fuse and it ran the tailights as well.
#3 nipper
nipper
    Semi Elite Master of the
  • 18,193 posts
  • Long Island NY
Posted 16 December 2008 - 07:20 PM
This happened to me, the virgin switch was in the middle. Move the parking light switch back and forth first and see if that fixes it.
nipper
#4 bratman18
bratman18
    ADIDASubarus
  • 3,846 posts
  • Jefferson, Maine
Posted 16 December 2008 - 07:32 PM
nipper
ahhh, yes I forgot about that! +1
#5 WickedV6
WickedV6
    USMB Regular
  • PipPipPip
  • 31 posts
  • ELBURN, IL
Posted 17 December 2008 - 01:54 PM
nipper
I did try that as well, no luck. I will check all the other fuses.
Thanks guys
Prasad
#6 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 17 December 2008 - 02:46 PM
DO the parking lights come on with the virgin switch? If it doesnt check the fuses. If it does its the relay.
nipper
#7 WickedV6
WickedV6
    USMB Regular
  • PipPipPip
  • 31 posts
  • ELBURN, IL
Posted 19 December 2008 - 09:50 AM
nipper
No, the parking lights do not come on with the virgin switch. I will go through every single fuse.
Thanks
Prasad
#8 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 19 December 2008 - 11:14 AM
Yup its a fuse. The switch bipasses the relay.
nipper
#9 WickedV6
WickedV6
    USMB Regular
  • PipPipPip
  • 31 posts
  • ELBURN, IL
Posted 22 December 2008 - 11:36 AM
As always you guys were right on the money. I double checked the fuses. This time I checked with a multimeter. The fuse for the parking lights looked perfectly fine but when I checked for continuity, it showed it was open. It had a hair line break in it. Repalced the fuse and we are all good.
Thanks again guys
Prasad
#10 lighthousekeeper
lighthousekeeper
    New User
  • Pip
  • 8 posts
  • Houston, Tx
Posted 29 December 2008 - 12:22 AM
I am having the same problem with my 1996 outback except i have checked every fuse with a multimeter for continuity and they are all fine. I even went so far as to check every fuse besides the air bag for continuity and they are all fine! I cannot get my dash or parking/tail lights to work only the brakes. The strange thing is that the lights will all flash on like they are supposed to when i click my remote starter/alarm. Im afraid i might need a new switch. Also what is the virgin switch you spoke of?
Thanks
#11 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 29 December 2008 - 12:26 AM
The switch on top of the steering column for the parking lights.
nipper
