Worth The Trouble
It will be a PITA to wire correctly, and route, better off using the kit - especially if the included switch is lighted -- so you don't forget they are on for oncoming traffic
new switch should fit nicely to the right of the headlight switch in the empty spot that is used for the panel dimmer on later models, unless the headlight switch is also the turnsignal lever......
subaru commercial was on when I started typing this post :banana:
it was about children's charity and Ramsey Subaru :grin:
