hypotheically speaking
6 replies to this topic
#1 Uberoo
Uberoo
    Subaru Wheeler
  • 3,863 posts
  • lewiston,ID
Posted 18 December 2008 - 03:22 PM
If I was to put a subaru or any other unibody car on a solid axle toyota frame,How much would that lift said subaru/unibody? With the stock tires on the toyota running gear. I have access to a toyota 4x4 solid axle rolling chassie. So just wondering...
#2 The Beast I Drive
The Beast I Drive
    CALL ME, (509) 391-5903
  • 2,120 posts
  • Toppenish, WA
Posted 18 December 2008 - 03:23 PM
Ask Monstaru, he did it, just never finished it...
-Bill
#3 one eye
one eye
    I'm A Subaholic
  • 2,593 posts
  • Mt.Vernon Washington
Posted 18 December 2008 - 11:24 PM
You would have a stock toyota with a subaru body on it. If you don't lift it, it would just look like a toyota pickup with a subaru body.
Might try this forum
http://www.toyotanat...isplay.php?f=81
I've seen people do it with honda's and stuff, maybe somthing there about it.
:horse:
Jeff
Edited by one eye, 18 December 2008 - 11:33 PM.
#4 mcbrat
mcbrat
    Brattitude Adjustment
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 19 December 2008 - 02:16 AM
Posted Image
from here...
http://www.rrr4x4.com/Jayson.html
#5 monstaru
monstaru
    wow, relevance....
  • 4,453 posts
  • OlyWa
Posted 19 December 2008 - 05:57 AM
its huge.where you run into issues is with the body mounts on the toyota frame,you almost just want to weld crossbars from side to side.but then it is really ridiculous.it takes a little finesse to get it to match up right as it sits.
but if a guy were to shorten it in the center where the transfer case crossmember was, it would be easier maybe.
it is defenitely fabbing eve3rything.nothing matches up.i got it all lined up and attached at a couple of points then got rid of that project.cheers, brian
#6 Andy FitzGibbon
Andy FitzGibbon
    Eat, Live, Breath Subaru
  • 335 posts
  • Elkins, WV
Posted 19 December 2008 - 06:42 AM
To make it sit any lower than in that photo, you would have to cut out a lot of the unibody/uniframe. Guys used to do that with Ford Pintos when I was growing up, and ran into the same issue.
Andy
#7 Uberoo
Uberoo
    Subaru Wheeler
  • 3,863 posts
  • lewiston,ID
Posted 19 December 2008 - 02:13 PM
so then it should be able to clear 33"s then?was that frame lifted any to start with?
Edited by Uberoo, 19 December 2008 - 02:18 PM.
