Coolant flush?
9 replies to this topic
#1 etc
etc
    USMB is life!
  • 207 posts
  • Maryland
Posted 19 December 2008 - 03:58 PM
1998 legacy L, 2.2L auto, 147K miles
How do I flush the coolant (Nothing good seen in the search)
#2 98obster
98obster
    USMB is life!
  • 248 posts
  • Greeley
Posted 19 December 2008 - 06:48 PM
I have done a "reverse" flush by disconnecting the driverside hose to the heater core and flushing with a garden hose.
#3 Rooster2
Rooster2
    Subaru Master
  • 2,869 posts
  • Indianapolis
Posted 19 December 2008 - 07:44 PM
If you live in a warm climate, water flush as described by 98OBster. You can also add a can of chemical flush, drive for a few days, drain, water flush, add 50/50 coolant/water to finish the job.
#4 etc
etc
    USMB is life!
  • 207 posts
  • Maryland
Posted 20 December 2008 - 12:13 PM
Can I just drain the radiator and then fill it up again?
#5 Durania
Durania
    Elite Master of the Subaru
  • 3,113 posts
  • Crossville, TN
Posted 20 December 2008 - 03:33 PM
You can but that is not considered a flush but a drain and fill. A flush is like 90obster described which involves flushing out the heater core and everything.
#6 etc
etc
    USMB is life!
  • 207 posts
  • Maryland
Posted 20 December 2008 - 04:04 PM
I opened the drain on the radiator but the coolant was coming out very slow, basically dripping. I know it should come out a lot faster than that.
Is the radiator plugged somehow? It was full when I looked into it.
#7 Durania
Durania
  • 3,113 posts
  • Crossville, TN
Posted 20 December 2008 - 07:40 PM
Did you have radiator cap off? Same principle as the portable gas can, air behind so liquid can go out. You could just disconnect the lower radiator hose.
#8 etc
etc
    USMB is life!
  • 207 posts
  • Maryland
Posted 20 December 2008 - 10:22 PM
Yes, the cap was off. It was a drip basically, not a stream.
#9 grossgary
grossgary
  • Gold Subscribers
  • 17,911 posts
  • West VA
Posted 21 December 2008 - 12:10 AM
the drain plug probably wasn't opened far enough or turned at the right angle? i think the notch in it has to line up right so to speak?
#10 etc
etc
    USMB is life!
  • 207 posts
  • Maryland
Posted 21 December 2008 - 01:32 AM
No, the drain plug was completely removed.
I drained the radiator on a Loyale one time and I know I got a stream instead of a drip like here.
