ea82 Alternator issue??
4 replies to this topic
#1 codytotheh
codytotheh
    USMB Regular
  • PipPipPip
  • 61 posts
  • up north, michigan
Posted 23 December 2008 - 01:05 AM
i replaced the alternator on my loyale, for some reason the new one isn't really putting out much of a charge maybe 13 is this normal??
#2 Loyale 2.7 Turbo
Loyale 2.7 Turbo
    The Mighty "BumbleBeast"
  • 4,765 posts
  • Roatán, Honduras.
Posted 23 December 2008 - 01:09 AM
Well... Maybe your old one was Delivering more Voltage than Normal... Try to Measure with a Tester the Total Amount of Voltage when the Car have the Headlamps On, and the Engine is Around 1,500 RPM`s ... if it still says 13, then it is Normal... if it Lowers Below 12V, it is Bad.
Good Luck!
#3 ()__1337_CRAYOLA__()>
    Soob Finatic
  • 621 posts
  • Burien/Des Moines
Posted 23 December 2008 - 01:48 AM
also your oe gauges arent that accurate anymore :lol: check it with a volt
meter
#4 codytotheh
codytotheh
    USMB Regular
  • PipPipPip
  • 61 posts
Posted 26 December 2008 - 03:03 AM
meter
the 13 was on a volt meter.
#5 The Scooby
The Scooby
    EJ Swap Junkie
  • 1,752 posts
  • South Seattle
Posted 26 December 2008 - 04:53 PM
the alt will only put out max volts above 2K rpms, so bring it up to about 2200rpms and check it again, should show 14.4 if its good.
