Infidel Posted December 31, 2008 Share Posted December 31, 2008 When I purchased my 98 OBS a while back the previous owner had put new wheels and tires on it, supposedly because the hubcaps kept getting stolen. She indicated that the tires weren't the right size so it would rub going over bumps or hauling loads. I had thought this may be due to weak rear springs, but now I think it's due to an incorrect offset on the aftermarket wheels. I'm looking into getting the propert sized wheels, either oem or aftermarket. Currently I have 205/60-15 tires, unsure of the wheel offset but the rubbing occurs on the very outside of the tire, a 10-15 mm change in offset would eliminate the rubbing. A newer model OBS parks right next to me at work, the OEM wheel set up is obviously narrower than mine, although they have 16 in wheels. So, what is the proper offset? What models/years OEM wheels should work? What is the original OEM set up on this car? Thanks all Quote Link to comment Share on other sites More sharing options...
bratman18 Posted December 31, 2008 Share Posted December 31, 2008 I think that I remember the stock size was 205 75 15 for an OB Quote Link to comment Share on other sites More sharing options...
Durania Posted December 31, 2008 Share Posted December 31, 2008 Is it posted in the driver's side door jamb? Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted December 31, 2008 Share Posted December 31, 2008 i take it this is an impreza outback sport? Quote Link to comment Share on other sites More sharing options...
bratman18 Posted December 31, 2008 Share Posted December 31, 2008 i take it this is an impreza outback sport? oh yeah oops I didn't see the S then the stock size would be a 205 60 15 and any wheels from any 15 or 16" subaru should fit properly Quote Link to comment Share on other sites More sharing options...
Infidel Posted December 31, 2008 Author Share Posted December 31, 2008 I've found several people sellling 16" OEM takeoffs near me for pretty cheap. Any clearance issues with running 16" on the OBS? Lower profile tires maybe to correct the overall diameter? Cheaper though if I can just find 15" wheels and put my current, nearly new, tires on them. Thanks for the info so far, 205/60-15 per the tag in the door. Quote Link to comment Share on other sites More sharing options...
bratman18 Posted December 31, 2008 Share Posted December 31, 2008 I've found several people sellling 16" OEM takeoffs near me for pretty cheap. Any clearance issues with running 16" on the OBS? Lower profile tires maybe to correct the overall diameter? Cheaper though if I can just find 15" wheels and put my current, nearly new, tires on them. Thanks for the info so far, 205/60-15 per the tag in the door. No as long as they are subaru 16" wheels they will fit fine. I have 205 55 16 on my Impreza 2.5RS so I'm sure you could use those or you could get some that are a little taller if you wanted, as my RS is a little lower than the OBS Quote Link to comment Share on other sites More sharing options...
wtdash Posted December 31, 2008 Share Posted December 31, 2008 http://www.1010tires.com/tiresizecalculator.asp This will allow you to compare tire sizes to the stock size and even tells you how much your speedo will be off....nice tool. Good luck. Quote Link to comment Share on other sites More sharing options...
Durania Posted December 31, 2008 Share Posted December 31, 2008 These are WRX 16's with stock REO70's on my 91 Legacy. Zero issues with rubbing and made it handle a lot better too. Quote Link to comment Share on other sites More sharing options...
Infidel Posted December 31, 2008 Author Share Posted December 31, 2008 Excellent, thank you all very much. Quote Link to comment Share on other sites More sharing options...
