Hard Cold Start
12 replies to this topic
#1 Sundance
Sundance
    USMB Regular
  • PipPipPip
  • 44 posts
  • North Dakota
Posted 10 January 2009 - 06:51 PM
My wife's '95 Legacy 2.2L has a cold start problem.
After sitting overnight in sub freezing temps it starts
really hard, and when it does start it chugs a bit.
Then it's fine.
When the temps are freezing or above it's not an
issue.
The car has new plugs, new plug wires, and we just
put a new fuel filter on.
What do you think????
#2 Sundance
Sundance
    USMB Regular
  • PipPipPip
  • 44 posts
  • North Dakota
Posted 10 January 2009 - 08:22 PM
Forgot.............. no check engine light so no apparent
codes.
#3 86subaru
86subaru
    Elite Master of the Subaru
  • 3,097 posts
  • ohio
Posted 10 January 2009 - 11:51 PM
hows the battery ,my 95 legacy did the same thing until i changed the battery mine was 7 years old , may or may not be the problem , autozone will check it for free,here is another thing since you in the deep freeze put a block heater on it ,
Edited by 86subaru, 11 January 2009 - 10:16 AM.
#4 Sundance
Sundance
    USMB Regular
  • PipPipPip
  • 44 posts
  • North Dakota
Posted 11 January 2009 - 12:50 PM
The battery is great.
It's like it isn't getting enough gas.
#5 abog
abog
    USMB is life!
  • 192 posts
  • reno
Posted 11 January 2009 - 04:20 PM
Have run into fuel problems on cold start several times. Will start hard and then die, after a couple of times will start and run ok, discovered that the poor volatility of some gasolines has a major effect on cold starts, clears up due to cylinder temperature coming up and excess fuel in cylinders from cranking and stalling. If this is the case, usually is easily cured by switching brand of fuel, or by adding a high quality fuel additive, such as lucas.
#6 Skip
Skip
    Flatuous Blather
  • Moderator
  • 8,991 posts
  • Latrobe, Pennsylvania
Posted 11 January 2009 - 04:27 PM
have you ever noticed the rad fans running at
a strange time?
If so the FI coolant thermosensor wants changed.
#7 Sundance
Sundance
    USMB Regular
  • PipPipPip
  • 44 posts
  • North Dakota
Posted 11 January 2009 - 07:23 PM
Haven't noticed any rad fan issues.
I have wondered about there being a temperature
sensor that would tell the computer when to apply
additional fuel. Would that be the coolant temp sensor?
We've done the fuel thing, it's have a few tanks of fuel
through it since this showed up. Added Heat and some
other additive/inj cleaner.
#8 four-fleet-feet
four-fleet-feet
    USMB is life!
  • 209 posts
  • Seattle
Posted 13 January 2009 - 03:02 PM
Just thought I'd throw this in.
What weight oil are you running? On my last oil change some *dojo* put in heavier oil than I run (let's just say it wasn't 5/30) and Dragon really didn't like starting in 14 degree weather. I knew my battery needed replacement, but even with a fully-charged fresh battery she didn't want to turn over and stay that way without a tap on the gas pedal (more than one, actually). She ran as rough as a washboard until she was up to full operating temp. Once she was hot she was running/starting as usual. Less than 1 year on NGK's, 60/40 antifreeze, gas with Heet and topped up with Premium. Couldn't figure out the cause until I called the dealer who'd done the oil change while I was on the road. Yes, they'd used heavier oil than I'd requested.
Replaced oil with lighter, usual weight. No problems now.
I wouldn't want to run with thicker oil in the c-c-cold weather we've all been having. If you do track this down to the oil I'd say a block heater is in your future if you're already running 5/30. Wish I had one this year! Maybe even a battery warmer.
So does everyone else in Seattle; none to be had. All backordered...:(
#9 subaru360
subaru360
    has no catchy title
  • 1,282 posts
  • Fleetwood, PA
Posted 13 January 2009 - 03:15 PM
Then it's fine.
issue.
Could be the coolant temp sensor, they act like this when they go bad.
#10 Skip
Skip
    Flatuous Blather
  • Moderator
  • 8,991 posts
Posted 13 January 2009 - 03:29 PM
Thats correct sir,
If you want to test it
the Factory Service Manual
shows
for 68 deg F the resistance should be 2.0 - 3.0 kilo OHMS
for 176 deg F the resistance should be 0.3 - 0.4 kilo OHMS
Here is a procedure for changing it with some good pictures
http://www.lovehorse...TempSensor.html
#11 zyewdall
zyewdall
    Subaru Master
  • 2,136 posts
  • Ward, CO
Posted 13 January 2009 - 06:54 PM
Growing up in Spokane/N. ID, and now living in Colorado, it seems kind of strange that anyone in Seattle would even need a block heater.... In Colorado, I only have one on the diesel truck, none of the gas vehicles, and they all start fine in single digit temps all winter.
Of course... I'm sure all the people in Minnesota and Alaska are laughing at me thinking that Colorado or Idaho is cold .... Single digits... you mean positive numbers? :lol:
#12 Dickensheets
Dickensheets
    Subaru Fanatic!
  • 452 posts
  • Las Cruces, NM
Posted 13 January 2009 - 10:45 PM
I know i'm wierd but all my vehicles have block heaters. Best $35 you can spend if it gets cold out. Not only is it nice to have effortless starting and instant heat but it's good for the motor plain and simple. Why more folks don't use them is a mystery to me.:-\
#13 nipper
nipper
    Semi Elite Master of the
  • 18,191 posts
  • Long Island NY
Posted 14 January 2009 - 12:14 AM
Give that man a lollypop.
Coolant Temp Sensor.
Wont throw a code because the car has to be running to throw a code, and once the car starts, its no longer an issue. I bet the CTS has a prblem at the bottm end (cold) of the resistance range.
nipper
