skybren Posted January 15, 2009 Share Posted January 15, 2009 Hello, I don't mean to bring up an old subject but... My auto transmission works fine when warmed up. But when it is first started when not warmed up I put it in drive or reverse and it sits there for a short time and does nothing eventually it will engage and then everything is fine. Any ideas out there also I do not want to go to a 5 spd, just want to get this problem fixed, thanks Quote Link to comment Share on other sites More sharing options...
Skip Posted January 15, 2009 Share Posted January 15, 2009 1) change the fluid by draining into a pan. 2) measure what you drained out 3) subract one quart and replace it with a quart of Lucus transmission honey or TransX 4) refill with new fluid plus additive, 5) check the trans fluid level when hot and running in nuetral If you feel real ambitious ....pull the pan and clean the filter (its a screen you can clean) Quote Link to comment Share on other sites More sharing options...
